Ir para o conteúdo principal
Logitech G432 Audio Cable Replacement
O que você precisa
  1. Logitech G432 Audio Cable Replacement, Earpad Cushions: passo 1, imagem 1 %32 Logitech G432 Audio Cable Replacement, Earpad Cushions: passo 1, imagem 2 %32
    • Carefully lift the cushion upward using your hands.
  2. Logitech G432 Audio Cable Replacement, Audio Cable: passo 2, imagem 1 %32 Logitech G432 Audio Cable Replacement, Audio Cable: passo 2, imagem 2 %32 Logitech G432 Audio Cable Replacement, Audio Cable: passo 2, imagem 3 %32
    • Remove the three 1.0 mm screws from the edge of the earpiece using a Phillips #0 screwdriver.
    • Use the pointed end of a spudger to remove the black sticker covering the fourth screw.
    • Remove the single 1.0 mm screw from beneath the sticker using a Phillips #0 screwdriver.
  3. Logitech G432 Audio Cable Replacement: passo 3, imagem 1 %32
    • Gently open the headpiece to prevent accidentally pulling apart any of the internal wiring.
  4. Logitech G432 Audio Cable Replacement: passo 4, imagem 1 %32
    • Raise the small component fastened to the wiring at the bottom of the earpiece to reveal each wire.
  5. Logitech G432 Audio Cable Replacement: passo 5, imagem 1 %32
    • Extend the wiring to expose the tiny knots located along the audio cable.
    • Unravel the knots to disconnect the wires using a soldering iron, making it possible to connect the new audio cable.
Conclusão
Lara Vasquez
Membro desde: 02/24/23
397 Reputação
Autoria de 4 guias
Equipe
Marist, Team 1-2, Chaterdon Spring 2023 Membro de Marist, Team 1-2, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G2
Membros da 3
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 34
Últimos 30 dias: 149
Duração total: 1,462
