Ir para o conteúdo principal
Logitech G305 Mouse Left Clicker Replacement
O que você precisa
  1. Logitech G305 Mouse Left Clicker Replacement, Left Clicker: passo 1, imagem 1 %32 Logitech G305 Mouse Left Clicker Replacement, Left Clicker: passo 1, imagem 2 %32
    • Remove the battery cover by pressing the top of the cover and pulling it downwards.
    • Remove the battery.
    Pergunte ao FixBot
    Comentar
  2. Logitech G305 Mouse Left Clicker Replacement: passo 2, imagem 1 %32 Logitech G305 Mouse Left Clicker Replacement: passo 2, imagem 2 %32 Logitech G305 Mouse Left Clicker Replacement: passo 2, imagem 3 %32
    • Carefully use a box cutter to follow the grooves of the mouse skate pads and slowly lift them off.
    • Use a Phillips #00 screwdriver to remove the four screws.
    Pergunte ao FixBot
    Comentar
  3. Logitech G305 Mouse Left Clicker Replacement: passo 3, imagem 1 %32 Logitech G305 Mouse Left Clicker Replacement: passo 3, imagem 2 %32
    • Use a spudger to carefully separate the two halves of the mouse near the battery compartment.
    Pergunte ao FixBot
    Comentar
  4. Logitech G305 Mouse Left Clicker Replacement: passo 4, imagem 1 %32 Logitech G305 Mouse Left Clicker Replacement: passo 4, imagem 2 %32
    • Open the compartment and slowly separate the halves until the internal wires are exposed.
    • Carefully disconnect the two wires by hand from the base.
    • The wires are fragile and require careful handling.
    Pergunte ao FixBot
    Comentar
  5. Logitech G305 Mouse Left Clicker Replacement: passo 5, imagem 1 %32 Logitech G305 Mouse Left Clicker Replacement: passo 5, imagem 2 %32 Logitech G305 Mouse Left Clicker Replacement: passo 5, imagem 3 %32
    • Remove the three screws from the center battery compartment using a Phillips #00 screwdriver.
    • Remove the two screws securing the left clicker.
    Pergunte ao FixBot
    Comentar
  6. Logitech G305 Mouse Left Clicker Replacement: passo 6, imagem 1 %32 Logitech G305 Mouse Left Clicker Replacement: passo 6, imagem 2 %32
    • Lift the battery compartment to gain easy access to the clicker.
    • Lift the battery compartment with care because of fragile wires.
    • Remove the left clicker.
    Pergunte ao FixBot
    Comentar
  7. Logitech G305 Mouse Left Clicker Replacement: passo 7, imagem 1 %32 Logitech G305 Mouse Left Clicker Replacement: passo 7, imagem 2 %32
    • Insert the replacement component and slide it into position until it securely clicks into place.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Juan Iniguez
Membro desde: 09/30/25
172 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 10
Últimos 7 dias: 71
Últimos 30 dias: 382
Ao todo: 2,443
