Ir para o conteúdo principal
Logitech G29 Driving Force Paddle Assembly Replacement
O que você precisa
  1. Logitech G29 Driving Force Paddle Assembly Replacement, Paddle Assembly: passo 1, imagem 1 %32
    • Remove the six 32 mm hex screws from the faceplate of the steering wheel.
    Pergunte ao FixBot
    Comentar
  2. Logitech G29 Driving Force Paddle Assembly Replacement: passo 2, imagem 1 %32
    • Remove the six 10 mm #00 Phillips screws from the back of the steering wheel.
    • Gently lift off the steering wheel from the hub.
    Pergunte ao FixBot
    Comentar
  3. Logitech G29 Driving Force Paddle Assembly Replacement: passo 3, imagem 1 %32
    • Carefully unplug the wire connector from the motherboard of the steering wheel.
    Pergunte ao FixBot
    Comentar
  4. Logitech G29 Driving Force Paddle Assembly Replacement: passo 4, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the three 30 mm screws that are behind the steering wheel.
    Pergunte ao FixBot
    Comentar
  5. Logitech G29 Driving Force Paddle Assembly Replacement: passo 5, imagem 1 %32
    • Gently pull the paddle assembly off from the base of the device and carefully thread the connector through the hole in the center.
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
3Comentários do guia
Where can I buy the paddle assembly
Kevin Junghans - Responder Compartilhar
@kevinjungh90689 have you found this out ? my paddle snapped off and I need to get a new one
Fizaan Ahmed - Responder Compartilhar
@fizaanahmed Perhaps eBay?
VauWeh - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 13
Últimos 7 dias: 53
Últimos 30 dias: 274
Ao todo: 8,965
