Ir para o conteúdo principal
Logitech G27 Internal Motors Replacement
O que você precisa
  1. Logitech G27 Internal Motors Replacement, Steering Wheel: passo 1, imagem 1 %32
    • Remove the six gray 25mm hex screws with a 4mm allen wrench.
    • Watch out when you lift the wheel up, as there are fragile wires connected to the bottom side.
    • Carefully lift up the wheel, but do not disconnect it from the rest of the device.
    Pergunte ao FixBot
    Comentar
  2. Logitech G27 Internal Motors Replacement: passo 2, imagem 1 %32
    • Carefully lift the wheel off of the hub, exposing the 2 shifter paddle wires and PCB board.
    Pergunte ao FixBot
    Comentar
  3. Logitech G27 Internal Motors Replacement: passo 3, imagem 1 %32
    • Remove the two 7.5 mm silver screws holding the green PCB board in the wheel with a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  4. Logitech G27 Internal Motors Replacement: passo 4, imagem 1 %32
    • Carefully remove the PCB board from the wheel hub.
    Pergunte ao FixBot
    Comentar
  5. Logitech G27 Internal Motors Replacement: passo 5, imagem 1 %32
    • Carefully pinch and unplug the large 7-pin connector under the PCB board.
    • Be careful when unplugging this adapter, try not to pull on the wires to avoid damaging them. Instead, wiggle around the plastic connector while pulling on it to loosen it.
    Pergunte ao FixBot
    Comentar
  6. Logitech G27 Internal Motors Replacement: passo 6, imagem 1 %32
    • You can now fully remove the wheel from the hub. Set it aside until you put the wheel back together.
    • Remove the innermost three 37.5mm silver screws with a Phillips #2 screwdriver.
    • Remove the wheel hub and push the connector through the center of the hub.
    Pergunte ao FixBot
    Comentar
  7. Logitech G27 Internal Motors Replacement: passo 7, imagem 1 %32
    • The wheel hub can now be set aside and flip over the steering wheel housing to reveal the under side.
    • Remove the eight 15.9mm silver surrounding screws underneath the wheel housing with a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  8. Logitech G27 Internal Motors Replacement: passo 8, imagem 1 %32
    • Rotate the housing back over and remove the top half of the housing revealing the majority of the components of the wheel.
    • The housing cover can be set aside until you put the wheel back together.
    Pergunte ao FixBot
    Comentar
  9. Logitech G27 Internal Motors Replacement: passo 9, imagem 1 %32
    • Remove the four 7.3mm silver screws attaching the green PCB board to the motor housing with a Phillips #2 screwdriver.
    Pergunte ao FixBot
    Comentar
  10. Logitech G27 Internal Motors Replacement: passo 10, imagem 1 %32
    • Unplug the three plastic connectors on the left side of the PCB board.
    • Unplug the two plastic connectors on the top of the PCB board.
    • Unplug the three plastic connectors on the right side of the PCB board.
    • Pulling the plastic connectors requires a lot of force, but be careful and don't pull directly on the wires. Try to wedge or push the male side of the connector out.
    • If you need some extra leverage when removing these connectors, try using a plastic opening tool to pry off the connectors.
    • Removing these connectors allows easier access to the four screws attaching the PCB board mount to the motor housing.
    Pergunte ao FixBot
    Comentar
  11. Logitech G27 Internal Motors Replacement: passo 11, imagem 1 %32
    • Remove the PCB board after all of the plastic connectors are disconnected.
    • You can now set it aside.
    Pergunte ao FixBot
    Comentar
  12. Logitech G27 Internal Motors Replacement: passo 12, imagem 1 %32
    • Remove the two 12.3mm upper black screws with a Phillips #2 screwdriver.
    • Remove the two 15.5mm bottom silver screws with a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  13. Logitech G27 Internal Motors Replacement: passo 13, imagem 1 %32 Logitech G27 Internal Motors Replacement: passo 13, imagem 2 %32
    • Remove the PCB board mount and remove the clear plastic piece underneath.
    • Set them aside until you reassemble the wheel.
    Pergunte ao FixBot
    Comentar
  14. Logitech G27 Internal Motors Replacement, Internal Motors: passo 14, imagem 1 %32 Logitech G27 Internal Motors Replacement, Internal Motors: passo 14, imagem 2 %32 Logitech G27 Internal Motors Replacement, Internal Motors: passo 14, imagem 3 %32
    • Remove the four 12.2mm screws using the Phillips screw driver.
    • The motors and gear box should now slide out. As you take it out, the metal spring band as well as the track for the wheel gear will also slide off.
    • During reinstallation, make sure when doing this step to align the stop on the wheel gear with the track as shown in the second and third pictures.
    • When you have separated these parts, you can set them aside until reassembly.
    Pergunte ao FixBot
    Comentar
  15. Logitech G27 Internal Motors Replacement: passo 15, imagem 1 %32
    • Next remove the eight 15.8mm screws that connect the plate holding the motors to the gear box.
    • When separating the gear box from the motor plate and motors be sure the gears do not fall out as they are difficult to put back in.
    Pergunte ao FixBot
    Comentar
  16. Logitech G27 Internal Motors Replacement: passo 16, imagem 1 %32 Logitech G27 Internal Motors Replacement: passo 16, imagem 2 %32
    • Remove the six 7.4mm screws that attach the motors to the motor plate and slide the motors off the motor plate.
    • The motor plate can be set aside and the motors can now be replaced.
    Pergunte ao FixBot
    Comentar
Conclusão
19 outras pessoas executaram este guia.
Max Barta
Membro desde: 04/21/15
583 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 15-4, Amido Spring 2015 Membro de Cal Poly, Team 15-4, Amido Spring 2015
CPSU-AMIDO-S15S15G4
4 Membros
Autoria de 25 guias
7Comentários do guia
Where can I buy this motors?
arthuru59 - Responder Compartilhar
If you do not feel confident doing this yourself, here is a link to a company that could do it for you http://www.mz-simulators.co.uk/services....
Okiura - Responder Compartilhar
Where can i buy this motors ?
onnepultrum - Responder Compartilhar
You can buy the motors from eBay :)
S2 KTS. - Responder Compartilhar
i found 1 of each
going to buy the encoder as well and start with it and then motors if needed
Jeff Bauer - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 10
Últimos 7 dias: 50
Últimos 30 dias: 181
Ao todo: 61,794
