Ir para o conteúdo principal
Logitech G27 C-Clamp Replacement
O que você precisa
  1. Logitech G27 C-Clamp  Replacement, Steering Wheel: passo 1, imagem 1 %32
    • Remove the six gray 25mm hex screws with a 4mm allen wrench.
    • Watch out when you lift the wheel up, as there are fragile wires connected to the bottom side.
    • Carefully lift up the wheel, but do not disconnect it from the rest of the device.
    Pergunte ao FixBot
    Comentar
  2. Logitech G27 C-Clamp  Replacement: passo 2, imagem 1 %32
    • Carefully lift the wheel off of the hub, exposing the 2 shifter paddle wires and PCB board.
    Pergunte ao FixBot
    Comentar
  3. Logitech G27 C-Clamp  Replacement: passo 3, imagem 1 %32
    • Remove the two 7.5 mm silver screws holding the green PCB board in the wheel with a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  4. Logitech G27 C-Clamp  Replacement: passo 4, imagem 1 %32
    • Carefully remove the PCB board from the wheel hub.
    Pergunte ao FixBot
    Comentar
  5. Logitech G27 C-Clamp  Replacement: passo 5, imagem 1 %32
    • Carefully pinch and unplug the large 7-pin connector under the PCB board.
    • Be careful when unplugging this adapter, try not to pull on the wires to avoid damaging them. Instead, wiggle around the plastic connector while pulling on it to loosen it.
    Pergunte ao FixBot
    Comentar
  6. Logitech G27 C-Clamp  Replacement: passo 6, imagem 1 %32
    • You can now fully remove the wheel from the hub. Set it aside until you put the wheel back together.
    • Remove the innermost three 37.5mm silver screws with a Phillips #2 screwdriver.
    • Remove the wheel hub and push the connector through the center of the hub.
    Pergunte ao FixBot
    Comentar
  7. Logitech G27 C-Clamp  Replacement: passo 7, imagem 1 %32
    • The wheel hub can now be set aside and flip over the steering wheel housing to reveal the under side.
    • Remove the eight 15.9mm silver surrounding screws underneath the wheel housing with a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  8. Logitech G27 C-Clamp  Replacement: passo 8, imagem 1 %32
    • Rotate the housing back over and remove the top half of the housing revealing the majority of the components of the wheel.
    • The housing cover can be set aside until you put the wheel back together.
    Pergunte ao FixBot
    Comentar
  9. Logitech G27 C-Clamp  Replacement: passo 9, imagem 1 %32
    • Remove the four 7.3mm silver screws attaching the green PCB board to the motor housing with a Phillips #2 screwdriver.
    Pergunte ao FixBot
    Comentar
  10. Logitech G27 C-Clamp  Replacement: passo 10, imagem 1 %32
    • Unplug the three plastic connectors on the left side of the PCB board.
    • Unplug the two plastic connectors on the top of the PCB board.
    • Unplug the three plastic connectors on the right side of the PCB board.
    • Pulling the plastic connectors requires a lot of force, but be careful and don't pull directly on the wires. Try to wedge or push the male side of the connector out.
    • If you need some extra leverage when removing these connectors, try using a plastic opening tool to pry off the connectors.
    • Removing these connectors allows easier access to the four screws attaching the PCB board mount to the motor housing.
    Pergunte ao FixBot
    Comentar
  11. Logitech G27 C-Clamp  Replacement: passo 11, imagem 1 %32
    • Remove the PCB board after all of the plastic connectors are disconnected.
    • You can now set it aside.
    Pergunte ao FixBot
    Comentar
  12. Logitech G27 C-Clamp  Replacement: passo 12, imagem 1 %32
    • Remove the two 12.3mm upper black screws with a Phillips #2 screwdriver.
    • Remove the two 15.5mm bottom silver screws with a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  13. Logitech G27 C-Clamp  Replacement: passo 13, imagem 1 %32 Logitech G27 C-Clamp  Replacement: passo 13, imagem 2 %32
    • Remove the PCB board mount and remove the clear plastic piece underneath.
    • Set them aside until you reassemble the wheel.
    Pergunte ao FixBot
    Comentar
  14. Logitech G27 C-Clamp  Replacement, C-Clamp: passo 14, imagem 1 %32
    • Unscrew the piece holding the C-Clamp in place with your hand.
    Pergunte ao FixBot
    Comentar
  15. Logitech G27 C-Clamp  Replacement: passo 15, imagem 1 %32 Logitech G27 C-Clamp  Replacement: passo 15, imagem 2 %32
    • Push the remaining nob forward and then inward through the slot.
    Pergunte ao FixBot
    Comentar
  16. Logitech G27 C-Clamp  Replacement: passo 16, imagem 1 %32 Logitech G27 C-Clamp  Replacement: passo 16, imagem 2 %32
    • The C-Clamp can now be easily pulled out of the bottom of the device.
    Pergunte ao FixBot
    Comentar
Conclusão
24 outras pessoas executaram este guia.
Daniel Louis
Membro desde: 04/28/15
758 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 15-4, Amido Spring 2015 Membro de Cal Poly, Team 15-4, Amido Spring 2015
CPSU-AMIDO-S15S15G4
4 Membros
Autoria de 25 guias
15Comentários do guia
Where would I buy the replacement C-Clamps from because one of mine are broken and I need to install a new one.
Mumin Mazhar - Responder Compartilhar
Look for it at eBay.
Eduardo - Responder Compartilhar
I also need to find a place to buy replacement C-clamps from
hockeyjockone - Responder Compartilhar
Can you tell me where I can buy these clamps?
kholiwen - Responder Compartilhar
step 9 to 13 not needed ... please confirm
Matt Na - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 35
Últimos 30 dias: 132
Ao todo: 50,397
