Ir para o conteúdo principal
Logitech G Cloud L2-R2 Trigger Replacement
O que você precisa
  1. Logitech G Cloud L2-R2 Trigger Replacement, Case: passo 1, imagem 1 %32 Logitech G Cloud L2-R2 Trigger Replacement, Case: passo 1, imagem 2 %32
    • Power the device off and turn it over so the screen is face down.
    • Insert an opening pick into the seam between the back plate and left handguard.
    • Pry around the entire perimeter until the handguard fully releases.
    • Remove the handguard.
    • Repeat the previous three bullets on the right handguard.
    Pergunte ao FixBot
    Comentar
  2. Logitech G Cloud L2-R2 Trigger Replacement: passo 2, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove all eight 10 mm screws from the rear case located under where the handguards were.
    Pergunte ao FixBot
    Comentar
  3. Logitech G Cloud L2-R2 Trigger Replacement: passo 3, imagem 1 %32 Logitech G Cloud L2-R2 Trigger Replacement: passo 3, imagem 2 %32
    • Insert an opening pick into the seam between the midframe and rear case.
    • Gently pry the rear case upwards to separate it from the midframe.
    Pergunte ao FixBot
    Comentar
  4. Logitech G Cloud L2-R2 Trigger Replacement: passo 4, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove all seven 10 mm screws that secure the midframe.
    Pergunte ao FixBot
    Comentar
  5. Logitech G Cloud L2-R2 Trigger Replacement: passo 5, imagem 1 %32 Logitech G Cloud L2-R2 Trigger Replacement: passo 5, imagem 2 %32
    • Insert an opening pick into the seam between the midframe and front case at the top of the device to separate the interior plating.
    • Gently pry out the midframe by lifting an opening pick.
    • You may hear loud popping noises when you remove the interior plating. That's the sound of the retaining clips disengaging.
    Pergunte ao FixBot
    Comentar
  6. Logitech G Cloud L2-R2 Trigger Replacement, L2-R2 Trigger: passo 6, imagem 1 %32 Logitech G Cloud L2-R2 Trigger Replacement, L2-R2 Trigger: passo 6, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove all four 10 mm screws that secure the L2 and R2 triggers.
    • Pop the L2 and R2 triggers out with your fingers.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 13
Últimos 30 dias: 59
Ao todo: 590
