Ir para o conteúdo principal
Logitech Cube Mouse Battery Replacement
O que você precisa
  1. Logitech Cube Mouse  Battery Replacement, Battery: passo 1, imagem 1 %32
    • Logitech Cube Mouse Battery Replacement/Removal
    Pergunte ao FixBot
    Comentar
  2. Logitech Cube Mouse  Battery Replacement: passo 2, imagem 1 %32
    • Peel the touchpad up from the support plate to make a 1 CM space.
    Pergunte ao FixBot
    Comentar
  3. Logitech Cube Mouse  Battery Replacement: passo 3, imagem 1 %32
    • Use a small thin object to pry outwards between the black plastic and white plastic to release two clips under the support plate.
    Pergunte ao FixBot
    Comentar
  4. Logitech Cube Mouse  Battery Replacement: passo 4, imagem 1 %32
    • After slowly releasing the two clips hinge up the touch panel 1 inch.
    Pergunte ao FixBot
    Comentar
  5. Logitech Cube Mouse  Battery Replacement: passo 5, imagem 1 %32
    • Slide the touch panel towards the back of the mouse 1CM.
    Pergunte ao FixBot
    Comentar
  6. Logitech Cube Mouse  Battery Replacement: passo 6, imagem 1 %32
    • Lift the touch panel and support plate.
    Pergunte ao FixBot
    Comentar
  7. Logitech Cube Mouse  Battery Replacement: passo 7, imagem 1 %32
    • Lift and rotate touch panel and support plate. Disconnect the touch panel connector, the other cable helps to sense touch.
    Pergunte ao FixBot
    Comentar
  8. Logitech Cube Mouse  Battery Replacement: passo 8, imagem 1 %32
    • Remove battery, battery plug from board connection, metal plate, and two screws. A notch in the plate matches a groove on the inside, removal at a angle is required.
    Pergunte ao FixBot
    Comentar
  9. Logitech Cube Mouse  Battery Replacement: passo 9, imagem 1 %32
    • Find another battery. Original is 533-000071 3.7v 240mAh 0.63IN x 1.18IN x 0.21IN or 16.002MM X 29.972MM X 5.334MM. There is some room for different lengths and widths, but height looks to be about 5.334MM. Due to my battery's width I had to bend a tab flat on the plate and only use 1 screw.
    Pergunte ao FixBot
    Comentar
  10. Logitech Cube Mouse  Battery Replacement: passo 10, imagem 1 %32
    • Press the touch pad and support plate together to undo slightly peeling them apart. Attach the battery to the plate, Install plate/ battery in mouse. Plug in battery and touch panel cables, rotate touch panel and support plate back into place. Place the front tab in its slot and press the back down to attach the clips to the bar.
    Pergunte ao FixBot
    Comentar
Conclusão
Unless the chosen battery is different, reassembly is in reverse order.
Brandon
Membro desde: 12/17/21
181 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 26
Ao todo: 1,465
