Ir para o conteúdo principal
Logitech G502 Hero Disassembly
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Logitech  G502 Hero Disassembly, Before we begin...: passo 1, imagem 1 %32
    • To keep it out of the way, wrap the USB cable using the integrated Velcro cable tie
    • If the Velcro cable tie is damaged or missing, a twist tie works just as well
    Pergunte ao FixBot
    Comentar
  2. Logitech  G502 Hero Disassembly, Remove bottom cover and weights: passo 2, imagem 1 %32 Logitech  G502 Hero Disassembly, Remove bottom cover and weights: passo 2, imagem 2 %32
    • Remove the weight cover from the bottom of the mouse by lifting it up by the mouse foot.
    • You can remove the tuning weights if desired, but this is not necessary for disassembly.
    Pergunte ao FixBot
    Comentar
  3. Logitech  G502 Hero Disassembly, Removing the mouse feet: passo 3, imagem 1 %32 Logitech  G502 Hero Disassembly, Removing the mouse feet: passo 3, imagem 2 %32 Logitech  G502 Hero Disassembly, Removing the mouse feet: passo 3, imagem 3 %32
    • Using a heat gun (set to low), heat up the three mouse feet for several seconds each.
    • Slide an opening pick under both the mouse feet and the adhesive underneath it.
    • If done correctly, you should be able to peel off the mouse feet with the adhesive still attached.
    • If the adhesive does not come off with the feet you can scrape it off with a spudger.
    Pergunte ao FixBot
    Comentar
  4. Logitech  G502 Hero Disassembly: passo 4, imagem 1 %32
    • Remove the four Phillips screws holding the two halves of the mouse together.
    Pergunte ao FixBot
    Comentar
  5. Logitech  G502 Hero Disassembly: passo 5, imagem 1 %32 Logitech  G502 Hero Disassembly: passo 5, imagem 2 %32
    • Insert the flat end of a plastic spudger into the area indicated between the top and bottom shells.
    • The two halves of the mouse will split almost completely apart with very little force.
    • Do not attempt to pull apart the two halves just yet.
    Pergunte ao FixBot
    Comentar
  6. Logitech  G502 Hero Disassembly: passo 6, imagem 1 %32 Logitech  G502 Hero Disassembly: passo 6, imagem 2 %32 Logitech  G502 Hero Disassembly: passo 6, imagem 3 %32
    • Insert the flat end of a plastic spudger between the top and bottom shells on the left side of the mouse, next to the left click.
    • The top and bottom shells will completely separate, allowing the top shell to be lifted off.
    • Use caution to avoid snapping the plastic clips holding the two halves together.
    Pergunte ao FixBot
    Comentar
  7. Logitech  G502 Hero Disassembly, Disconnecting Hero sensor: passo 7, imagem 1 %32 Logitech  G502 Hero Disassembly, Disconnecting Hero sensor: passo 7, imagem 2 %32 Logitech  G502 Hero Disassembly, Disconnecting Hero sensor: passo 7, imagem 3 %32
    • Using the flat end of a plastic spudger, carefully lift up both sides of the lock that secures the ribbon cable.
    • With the lock released, the ribbon cable should easily be removed from the connector.
    • Do not use too much force releasing the lock, otherwise the connector may be damaged.
    Pergunte ao FixBot
    Comentar
  8. Logitech  G502 Hero Disassembly, Removing side button board: passo 8, imagem 1 %32 Logitech  G502 Hero Disassembly, Removing side button board: passo 8, imagem 2 %32 Logitech  G502 Hero Disassembly, Removing side button board: passo 8, imagem 3 %32
    • Remove the side board by pulling it straight out to access the ribbon cable connector.
    • Using the same technique that was used with the Hero sensor ribbon cable connector, disengage the cable lock.
    • Remove the ribbon cable with the side board.
    Pergunte ao FixBot
    Comentar
  9. Logitech  G502 Hero Disassembly, Scroll wheel assembly - Part 1: passo 9, imagem 1 %32 Logitech  G502 Hero Disassembly, Scroll wheel assembly - Part 1: passo 9, imagem 2 %32 Logitech  G502 Hero Disassembly, Scroll wheel assembly - Part 1: passo 9, imagem 3 %32
    • The scroll wheel assembly is held in by a retaining bar, which will need to be removed
    • Using the pointed end of a plastic spudger, push the retaining bar out from the right side.
    • Once you've done this you can remove the retaining bar.
    Pergunte ao FixBot
    Comentar
  10. Logitech  G502 Hero Disassembly, Scroll wheel assembly - Part 2: passo 10, imagem 1 %32 Logitech  G502 Hero Disassembly, Scroll wheel assembly - Part 2: passo 10, imagem 2 %32
    • Pull the scroll wheel assembly off of the mouse.
    • There are two small springs for the scroll wheel click actions; these are very small and easily lost.
    Pergunte ao FixBot
    Comentar
  11. Logitech  G502 Hero Disassembly, Remove main board screws: passo 11, imagem 1 %32 Logitech  G502 Hero Disassembly, Remove main board screws: passo 11, imagem 2 %32 Logitech  G502 Hero Disassembly, Remove main board screws: passo 11, imagem 3 %32
    • Remove the four Phillips screws near the front of the mouse.
    • Remove the Phillips screw near the ribbon cable plug for the Hero sensor.
    • The cradle for the scroll wheel assembly can now be removed.
    Pergunte ao FixBot
    Comentar
  12. Logitech  G502 Hero Disassembly, Disconnect USB plug: passo 12, imagem 1 %32 Logitech  G502 Hero Disassembly, Disconnect USB plug: passo 12, imagem 2 %32 Logitech  G502 Hero Disassembly, Disconnect USB plug: passo 12, imagem 3 %32
    • Using the flat end of a plastic spudger, disconnect the USB cable plug from the main board by pushing out the male end of the plug.
    • Once there is enough of a small gap, the pointed end of the spudger can be used to push the plug out
    • Remove the main board from the mouse bottom shell.
    Pergunte ao FixBot
    Comentar
  13. Logitech  G502 Hero Disassembly, Removing Hero sensor: passo 13, imagem 1 %32 Logitech  G502 Hero Disassembly, Removing Hero sensor: passo 13, imagem 2 %32 Logitech  G502 Hero Disassembly, Removing Hero sensor: passo 13, imagem 3 %32
    Ferramenta utilizada neste passo:
    • With the main board removed, the Hero sensor board is revealed.
    • Remove the two Phillips screws holding the Hero board in.
    • Using tweezers, carefully remove the two nylon spacers from the posts.
    • Remove the Hero sensor board.
    Pergunte ao FixBot
    Comentar
  14. Logitech  G502 Hero Disassembly, Remove USB cable from bottom shell: passo 14, imagem 1 %32 Logitech  G502 Hero Disassembly, Remove USB cable from bottom shell: passo 14, imagem 2 %32 Logitech  G502 Hero Disassembly, Remove USB cable from bottom shell: passo 14, imagem 3 %32
    • Start by taking off the clear plastic piece on top of the cable stress reliever.
    • With the clear plastic piece remove, the cable can be removed at the stress reliever and bottom shell.
    Pergunte ao FixBot
    Comentar
  15. Logitech  G502 Hero Disassembly, End: passo 15, imagem 1 %32 Logitech  G502 Hero Disassembly, End: passo 15, imagem 2 %32 Logitech  G502 Hero Disassembly, End: passo 15, imagem 3 %32
    • All internal components for reference
    • Phillips screws
    • Scroll wheel springs
    • Hero sensor nylon spacers
    • Ribbon cables for side board and Hero sensor board
    • Scroll wheel assembly
    • Scroll wheel cradles and retaining bar
    Pergunte ao FixBot
    Comentar
Conclusão
Replace necessary parts and then follow these instructions in reverse order to reassemble.
67 outras pessoas executaram este guia.
spslizer
Membro desde: 03/10/20
2.163 Reputação
Autoria de 2 guias
34Comentários do guia
What’s that button near at the spring on top. Is that a middle mouse button? (yellow button thing at the middle at the top)
Nicholin V - Responder Compartilhar
You are correct, that is the middle mouse button
spslizer - Responder Compartilhar
What’s a good replacement switch for the 2 main left/right buttons? They say OMRON 3159C21 D2FC-F-K
Anthony Clark - Responder Compartilhar
That’s a good switch to replace them with
Me personally, I like to pull the switches off of other mice, like those rebranded Logitech ones that are bundled with some computers
The G502 is easy enough to pull apart and put back together that I don't mind replacing the switches on occasion
Oh shoot, you have to do soldering to replace switches? Those black boxes? Yikes, may be something I dont want to mess with if so. If I can just figure out how to clean them I will try that, but if I have to replace them with soldering, I am doomed lol
Living Simple And Fun - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 29
Últimos 7 dias: 247
Últimos 30 dias: 1,298
Ao todo: 208,136
