Ir para o conteúdo principal
Linsay Model F-7HD2CORE Screen Replacement
O que você precisa
    1. Linsay Model F-7HD2CORE Screen Replacement, Screen: passo 1, imagem 1 %32 Linsay Model F-7HD2CORE Screen Replacement, Screen: passo 1, imagem 2 %32 Linsay Model F-7HD2CORE Screen Replacement, Screen: passo 1, imagem 3 %32
      • Insert your plastic opening tool in between the black and white portions of your device.
      • Gently pry the top screen from the base of the tablet.
      • Your tablet should now look like the third photo.
      Pergunte ao FixBot
      Comentar
    2. Linsay Model F-7HD2CORE Screen Replacement: passo 2, imagem 1 %32 Linsay Model F-7HD2CORE Screen Replacement: passo 2, imagem 2 %32
      • Peel the microphone from the back of the device.
      Pergunte ao FixBot
      Comentar
    3. Linsay Model F-7HD2CORE Screen Replacement: passo 3, imagem 1 %32
      • Remove the tape from the indicated copper strip.
      Pergunte ao FixBot
      Comentar
    4. Linsay Model F-7HD2CORE Screen Replacement: passo 4, imagem 1 %32 Linsay Model F-7HD2CORE Screen Replacement: passo 4, imagem 2 %32
      • Use your 00 phillips head screwdriver to remove the three 4mm phillips screws circled in red.
      Pergunte ao FixBot
      Comentar
    5. Linsay Model F-7HD2CORE Screen Replacement: passo 5, imagem 1 %32
      • Remove the soldered portion of the circuit board on the screen.
      • You will need a soldering kit to reattach this part.
      Pergunte ao FixBot
      Comentar
    6. Linsay Model F-7HD2CORE Screen Replacement: passo 6, imagem 1 %32 Linsay Model F-7HD2CORE Screen Replacement: passo 6, imagem 2 %32
      • Use the blunt end of the spudger to remove the circuit panel and battery from the glass screen portion of the device.
      • There will be several small hooks holding the screen onto the back panel.
      Pergunte ao FixBot
      Comentar
    7. Linsay Model F-7HD2CORE Screen Replacement: passo 7, imagem 1 %32 Linsay Model F-7HD2CORE Screen Replacement: passo 7, imagem 2 %32
      • Gently pull the two pieces of the tablet apart.
      • Your tablet should now look like image two.
      • You are now ready to attach your new screen!
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
Penn State, Team 1-5, Kaschak Winter 2015 Membro de Penn State, Team 1-5, Kaschak Winter 2015
PSU-KASCHAK-W15S1G5
3 Membros
Autoria de 2 guias
1Comentário do guia
Excellent work!
Glen Lind - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 41
Ao todo: 1,670
