Ir para o conteúdo principal
Linsay Model F-7HD2CORE Battery Replacement
O que você precisa
    1. Linsay Model F-7HD2CORE Battery Replacement, Battery: passo 1, imagem 1 %32 Linsay Model F-7HD2CORE Battery Replacement, Battery: passo 1, imagem 2 %32 Linsay Model F-7HD2CORE Battery Replacement, Battery: passo 1, imagem 3 %32
      • Carefully insert your plastic opening tool in between the white and black sections of your device.
      • Gently pry the top screen portion from the base of the tablet.
      • Your tablet should now look like the third image.
      Pergunte ao FixBot
      Comentar
    2. Linsay Model F-7HD2CORE Battery Replacement: passo 2, imagem 1 %32 Linsay Model F-7HD2CORE Battery Replacement: passo 2, imagem 2 %32
      • To completely remove the base from the top of the tablet, peel the microphone from the back.
      Pergunte ao FixBot
      Comentar
    3. Linsay Model F-7HD2CORE Battery Replacement: passo 3, imagem 1 %32 Linsay Model F-7HD2CORE Battery Replacement: passo 3, imagem 2 %32
      • Remove the two pieces of tape holding the battery in place by gently peeling it off.
      Pergunte ao FixBot
      Comentar
    4. Linsay Model F-7HD2CORE Battery Replacement: passo 4, imagem 1 %32
      • Using the spudger, carefully peel the battery off of the tablet panel.
      • Tape of the back of the battery will be very strong, pull gently!
      • The metal exterior of the battery can be quite pliable. Use caution when removing the battery from the tablet.
      Pergunte ao FixBot
      Comentar
    5. Linsay Model F-7HD2CORE Battery Replacement: passo 5, imagem 1 %32
      • To remove the battery, completely desolder the wires connected to the circuit board.
      • To reattach the new battery, you must solder the wires back on.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
Penn State, Team 1-5, Kaschak Winter 2015 Membro de Penn State, Team 1-5, Kaschak Winter 2015
PSU-KASCHAK-W15S1G5
3 Membros
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 38
Ao todo: 1,808
