Ir para o conteúdo principal
Linksys WRT54G Motherboard Replacement
O que você precisa
  1. Linksys WRT54G Motherboard Replacement, Antennas: passo 1, imagem 1 %32
    • Unfold the antennas straight away from the device.
  2. Linksys WRT54G Motherboard Replacement: passo 2, imagem 1 %32 Linksys WRT54G Motherboard Replacement: passo 2, imagem 2 %32 Linksys WRT54G Motherboard Replacement: passo 2, imagem 3 %32
    • Remove the black caps from the antennas by pulling them away from the device.
  3. Linksys WRT54G Motherboard Replacement: passo 3, imagem 1 %32 Linksys WRT54G Motherboard Replacement: passo 3, imagem 2 %32 Linksys WRT54G Motherboard Replacement: passo 3, imagem 3 %32
    • Unscrew each of the antennas from the wireless device.
  4. Linksys WRT54G Motherboard Replacement, Casing: passo 4, imagem 1 %32 Linksys WRT54G Motherboard Replacement, Casing: passo 4, imagem 2 %32
    • Using a bit of force, remove the blue plastic case.
  5. Linksys WRT54G Motherboard Replacement, Motherboard: passo 5, imagem 1 %32 Linksys WRT54G Motherboard Replacement, Motherboard: passo 5, imagem 2 %32
    • To remove the black casing that surrounds the green motherboard, slide the top half of the casing backwards. It only moves a very short distance.
    • Pull the top piece upwards and away from the bottom to remove.
  6. Linksys WRT54G Motherboard Replacement: passo 6, imagem 1 %32 Linksys WRT54G Motherboard Replacement: passo 6, imagem 2 %32
    • Locate the 2 M2.5x6mm screws that attach the motherboard to the back case.
    • Remove the two screws from the motherboard as indicated with the Phillips head screwdriver.
  7. Linksys WRT54G Motherboard Replacement: passo 7, imagem 1 %32
    • Once screws have been removed, slide the motherboard in the direction of its LED lights.
    • Lift motherboard up and away from the black lower casing.
Conclusão
3 outras pessoas executaram este guia.
Aaron Brown
Membro desde: 10/11/11
163 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 17-7, Regan Fall 2011 Membro de Cal Poly, Team 17-7, Regan Fall 2011
CPSU-REGAN-F11S17G7
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 3,405
