Ir para o conteúdo principal
Linksys WRT54G Antennas Replacement
O que você precisa
  1. Linksys WRT54G Antennas Replacement, Antennas: passo 1, imagem 1 %32
    • Unfold the antennas straight away from the device.
  2. Linksys WRT54G Antennas Replacement: passo 2, imagem 1 %32 Linksys WRT54G Antennas Replacement: passo 2, imagem 2 %32 Linksys WRT54G Antennas Replacement: passo 2, imagem 3 %32
    • Remove the black caps from the antennas by pulling them away from the device.
  3. Linksys WRT54G Antennas Replacement: passo 3, imagem 1 %32 Linksys WRT54G Antennas Replacement: passo 3, imagem 2 %32 Linksys WRT54G Antennas Replacement: passo 3, imagem 3 %32
    • Unscrew each of the antennas from the wireless device.
  4. Linksys WRT54G Antennas Replacement, Antennas: passo 4, imagem 1 %32 Linksys WRT54G Antennas Replacement, Antennas: passo 4, imagem 2 %32
    • Once the old antennas are removed, replace them with them with the new ones by screwing them on the device.
Conclusão
Aaron Brown
Membro desde: 10/11/11
163 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 17-7, Regan Fall 2011 Membro de Cal Poly, Team 17-7, Regan Fall 2011
CPSU-REGAN-F11S17G7
Membros da 4
Autoria de 4 guias
2 comentários
I have a wrt54gs and the antennas are plastic crap with no cuff to unscrew. They are fastened in by "body snaps" like most of the cheap crap that's made in china. Off to find instructions for router disassembly. Just thought you should know this won't necessarily work for the models listed.
Ed Rutmayer - Responder
Most do not have removeable antennaes
tom - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Duração total: 5,786
