Ir para o conteúdo principal
Linksys WAP54g Bottom Casing/Motherboard Replacement
O que você precisa
  1. Linksys WAP54g Bottom Casing/Motherboard Replacement, Top Casing: passo 1, imagem 1 %32
    • Power down and unplug the device.
  2. Linksys WAP54g Bottom Casing/Motherboard Replacement: passo 2, imagem 1 %32
  3. Linksys WAP54g Bottom Casing/Motherboard Replacement: passo 3, imagem 1 %32
    • Remove the two black rubber feet of the device using the screwdriver. The feet are located on the bottom towards the front.
  4. Linksys WAP54g Bottom Casing/Motherboard Replacement: passo 4, imagem 1 %32
    • Once the feet are removed, two small screws will be visible. With a small screwdriver, unscrew them. Screws are phillips head, 4.35 mm in diameter, 7.88 mm in length.
  5. Linksys WAP54g Bottom Casing/Motherboard Replacement: passo 5, imagem 1 %32
    • To remove the front blue panel, grip firmly and place thumbs in the two notches on top. Push thumbs forward while keeping a firm grip on bottom.
    • This may require a bit of force.
  6. Linksys WAP54g Bottom Casing/Motherboard Replacement: passo 6, imagem 1 %32
    • Now slide the bottom panel forward and remove it so the top casing is isolated from the bottom casing and motherboard.
  7. Linksys WAP54g Bottom Casing/Motherboard Replacement: passo 7, imagem 1 %32 Linksys WAP54g Bottom Casing/Motherboard Replacement: passo 7, imagem 2 %32
    • Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts.
  8. Linksys WAP54g Bottom Casing/Motherboard Replacement: passo 8, imagem 1 %32 Linksys WAP54g Bottom Casing/Motherboard Replacement: passo 8, imagem 2 %32
    • From here, remove the wires and nuts connected to the back panel by pulling the nuts through the holes.
    • Now the top casing has been removed and isolated from the rest of the device. From here, you can make repairs to the top casing.
    • Once the top panel is removed the main board will still be attached to the bottom panel.
  9. Linksys WAP54g Bottom Casing/Motherboard Replacement, Bottom Casing/Motherboard: passo 9, imagem 1 %32 Linksys WAP54g Bottom Casing/Motherboard Replacement, Bottom Casing/Motherboard: passo 9, imagem 2 %32
    • Unscrew the two screws that connect the motherboard to the bottom casing.
    • The motherboard and bottom casing should be completely separated at this point. This allows for replacement of the motherboard and/ or its components as well as the bottom casing.
Conclusão
After the motherboard is isolated component level repairs can be made.
Mathew Fuller
Membro desde: 10/04/11
146 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 21-21, Maness Fall 2011 Membro de Cal Poly, Team 21-21, Maness Fall 2011
CPSU-MANESS-F11S21G21
Membros da 5
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 2,615
