Ir para o conteúdo principal
Linksys WAP 11 Outer Case Replacement
O que você precisa
    1. Linksys WAP 11 Outer Case Replacement, Outer Case: passo 1, imagem 1 %32
      • Disconnect the power cables and ethernet from the device.
      • Unscrew the external plastic antennas. There is one antenna on each side of the device.
      Pergunte ao FixBot
      Comentar
    2. Linksys WAP 11 Outer Case Replacement: passo 2, imagem 1 %32 Linksys WAP 11 Outer Case Replacement: passo 2, imagem 2 %32 Linksys WAP 11 Outer Case Replacement: passo 2, imagem 3 %32
      Ferramenta utilizada neste passo:
      • To open the Linksys WAP11, you will need a Phillips #1 screwdriver and a pair of metal tweezers.
      • Use the tweezers to remove the two rubber boots from the front two legs. Insert the tweezers in the hole of the boot and pull outwards.
      • This will reveal two small Phillips-head screws. Remove them.
      • Keep these two screws together.
      Pergunte ao FixBot
      Comentar
    3. Linksys WAP 11 Outer Case Replacement: passo 3, imagem 1 %32 Linksys WAP 11 Outer Case Replacement: passo 3, imagem 2 %32
      • Using two hands, pull on the top and bottom sections to separate the blue and the black pieces.
      • This requires significant amount of force.
      • The seal is located where the blue plastic meets the black plastic. This is where you will apply pressure.
      Pergunte ao FixBot
      Comentar
    4. Linksys WAP 11 Outer Case Replacement: passo 4, imagem 1 %32
      • After the face of the device has been removed, slide the base of the device off to reveal the motherboard and other internal components.
      • When removing the base, do not damage the wires that are attached to the device.
      Pergunte ao FixBot
      Comentar
    5. Linksys WAP 11 Outer Case Replacement: passo 5, imagem 1 %32
      • This is what the device looks like when it is fully opened.
      Pergunte ao FixBot
      Comentar
Conclusão
Joe M
Membro desde: 10/12/11
159 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 3-17, Regan Fall 2011 Membro de Cal Poly, Team 3-17, Regan Fall 2011
CPSU-REGAN-F11S3G17
5 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 24
Ao todo: 1,390
