Introdução
In the following guide you will be taking apart the outer casing to the Linksys EA9200, and desoldering the USB port from the circuit board. To complete this USB removal you will need to have several tools as well as some practice desoldering. Both the tools needed as well as the steps to practicing desoldering are included in the guide.
Ferramentas
Peças
Nenhum componente especificado.
Remove the sticker on the bottom.
Remove the two screws holding the bottom plate in place. Use Phillips screwdriver tip #1 , the screw head-size is 5mm.
Quase terminado!
Conclusão
