Ir para o conteúdo principal
Linksys EA9200 Power Switch Replacement
O que você precisa
  1. Linksys EA9200 Power Switch Replacement, Linksys EA9200 Disassembly: passo 1, imagem 1 %32 Linksys EA9200 Power Switch Replacement, Linksys EA9200 Disassembly: passo 1, imagem 2 %32
    • Remove the sticker on the bottom.
    • Remove the two screws holding the bottom plate in place. Use Phillips screwdriver tip #1 , the screw head-size is 5mm.
  2. Linksys EA9200 Power Switch Replacement: passo 2, imagem 1 %32 Linksys EA9200 Power Switch Replacement: passo 2, imagem 2 %32
    • Remove the back sticker that has all the labels.
    • There are two screws to remove. They are 6mm in diameter, use phillips screw tip #1.
  3. Linksys EA9200 Power Switch Replacement: passo 3, imagem 1 %32 Linksys EA9200 Power Switch Replacement: passo 3, imagem 2 %32 Linksys EA9200 Power Switch Replacement: passo 3, imagem 3 %32
    • Depress the 12 clips along the edge into the router. Use the nylon spudger as using a metal object could cause damage.
  4. Linksys EA9200 Power Switch Replacement: passo 4, imagem 1 %32 Linksys EA9200 Power Switch Replacement: passo 4, imagem 2 %32 Linksys EA9200 Power Switch Replacement: passo 4, imagem 3 %32
    • Once you have one side open, keep a spudger wedged between both sides. This will help keep it open in case it tries to snap back together.
    • These clips are tough and may need some additional force.
  5. Linksys EA9200 Power Switch Replacement: passo 5, imagem 1 %32 Linksys EA9200 Power Switch Replacement: passo 5, imagem 2 %32 Linksys EA9200 Power Switch Replacement: passo 5, imagem 3 %32
    • Lift the board and pull down, away from the antennas.
  6. Linksys EA9200 Power Switch Replacement, Power Switch: passo 6, imagem 1 %32 Linksys EA9200 Power Switch Replacement, Power Switch: passo 6, imagem 2 %32 Linksys EA9200 Power Switch Replacement, Power Switch: passo 6, imagem 3 %32
    • Desolder the 7 pins for the power switch from the backside of the circuit board.
    • In order to remove this part you will need a soldering iron that is capable of reaching temperatures greater than 300 degrees Fahrenheit.
    • Como soldar e dessoldar contatos is iFixit's official guide on how to use a soldering iron.
Conclusão
Shane Davis
Membro desde: 10/05/16
374 Reputação
3 Guias de autoria
Equipe
USF Tampa, Team 9-1, Lacy Fall 2016 Membro de USF Tampa, Team 9-1, Lacy Fall 2016
USFT-LACY-F16S9G1
4 Membros
10 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 428
