Introdução
In the following guide you will be taking apart the outer casing to the Linksys EA9200, and desoldering the Antenna port from the circuit board. To complete this Antenna port removal you will need to have several tools as well as some practice desoldering. Both the tools needed as well as the steps to practicing desoldering are included in the guide.
O que você precisa
Remove the sticker on the bottom.
Remove the two screws holding the bottom plate in place. Use Phillips screwdriver tip #1 , the screw head-size is 5mm.
The antenna ports are connected to the board with a wire that has a "snap" connector.
