Ir para o conteúdo principal
Lexmark Intuition S505 Ink Cartridges Replacement
  1. Lexmark Intuition S505 Ink Cartridges Replacement, Ink Cartridges: passo 1, imagem 1 %32 Lexmark Intuition S505 Ink Cartridges Replacement, Ink Cartridges: passo 1, imagem 2 %32
    • Lift the scanning unit, exposing the print head.
    Pergunte ao FixBot
    Comentar
  2. Lexmark Intuition S505 Ink Cartridges Replacement: passo 2, imagem 1 %32
    • Locate the frame around the ink cartridges. Press the button located at the front of the cartridge frame.
    Pergunte ao FixBot
    Comentar
  3. Lexmark Intuition S505 Ink Cartridges Replacement: passo 3, imagem 1 %32
    • Lift the frame to expose the ink cartridges.
    Pergunte ao FixBot
    Comentar
  4. Lexmark Intuition S505 Ink Cartridges Replacement: passo 4, imagem 1 %32
    • Push the button located above the designated ink cartridge until it pops out.
    Pergunte ao FixBot
    Comentar
  5. Lexmark Intuition S505 Ink Cartridges Replacement: passo 5, imagem 1 %32
    • Pull the cartridge out, and place the new ink cartridge back into the slot. Push until you hear a click.
    Pergunte ao FixBot
    Comentar
  6. Lexmark Intuition S505 Ink Cartridges Replacement: passo 6, imagem 1 %32 Lexmark Intuition S505 Ink Cartridges Replacement: passo 6, imagem 2 %32
    • Close the scanner unit.
    Pergunte ao FixBot
    Comentar
Conclusão
Once your ink cartridges are in place, your printer should now print high-quality documents.
3 outras pessoas executaram este guia.
Omar
Membro desde: 01/23/13
132 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 18-38, Regan Winter 2013 Membro de Cal Poly, Team 18-38, Regan Winter 2013
CPSU-REGAN-W13S18G38
4 Membros
Autoria de 8 guias
3Comentários do guia
Hello there, thanks for your demonstration. In case that the cartridges are not genuine (not a lexmark brand), will the printer will be able to print?
I own this model. Thanks in advance!
Dimitri Sideris - Responder Compartilhar
Merci beaucoup pour tout
Bouzebiba - Responder Compartilhar
Merci beaucoup pour votre compréhension et bonne journée également bisous 😚
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 42
Ao todo: 3,773
