Ir para o conteúdo principal
Levoit Core 300-RAC Power Cord Replacement
O que você precisa
    1. Levoit Core 300-RAC Power Cord Replacement, Air Filter: passo 1, imagem 1 %32 Levoit Core 300-RAC Power Cord Replacement, Air Filter: passo 1, imagem 2 %32
      • Make sure your device is turned off and unplugged for safety.
      • Turn the Levoit Core 300-RAC over so the bottom is facing up.
      Pergunte ao FixBot
      Comentar
    2. Levoit Core 300-RAC Power Cord Replacement: passo 2, imagem 1 %32 Levoit Core 300-RAC Power Cord Replacement: passo 2, imagem 2 %32 Levoit Core 300-RAC Power Cord Replacement: passo 2, imagem 3 %32
      • Turn the bottom cover counterclockwise and lift it off to remove it.
      • The cover does not "snap" on or off when turned.
      Pergunte ao FixBot
      Comentar
    3. Levoit Core 300-RAC Power Cord Replacement: passo 3, imagem 1 %32 Levoit Core 300-RAC Power Cord Replacement: passo 3, imagem 2 %32 Levoit Core 300-RAC Power Cord Replacement: passo 3, imagem 3 %32
      • Lift the filter straight up and out of the device.
      Pergunte ao FixBot
      Comentar
    1. Levoit Core 300-RAC Power Cord Replacement, Power Cord: passo 4, imagem 1 %32 Levoit Core 300-RAC Power Cord Replacement, Power Cord: passo 4, imagem 2 %32 Levoit Core 300-RAC Power Cord Replacement, Power Cord: passo 4, imagem 3 %32
      • Use a Phillips #2 screwdriver to remove the four screws that go through the four white tabs inside the device
      • Set the screws aside in a safe place.
      Pergunte ao FixBot
      Comentar
    2. Levoit Core 300-RAC Power Cord Replacement: passo 5, imagem 1 %32 Levoit Core 300-RAC Power Cord Replacement: passo 5, imagem 2 %32 Levoit Core 300-RAC Power Cord Replacement: passo 5, imagem 3 %32
      • Use a metal spudger to gently pry between the four white tabs and the white housing and release the outer housing.
      • Gently pull up on the outer housing to prevent the clips from resetting.
      Pergunte ao FixBot
      Comentar
    3. Levoit Core 300-RAC Power Cord Replacement: passo 6, imagem 1 %32 Levoit Core 300-RAC Power Cord Replacement: passo 6, imagem 2 %32
      • Remove the white outer housing and set it to the side.
      • The power cord is fed through a hole in the side of this housing, so it will need to be right next to the rest of the device.
      Pergunte ao FixBot
      Comentar
    4. Levoit Core 300-RAC Power Cord Replacement: passo 7, imagem 1 %32 Levoit Core 300-RAC Power Cord Replacement: passo 7, imagem 2 %32 Levoit Core 300-RAC Power Cord Replacement: passo 7, imagem 3 %32
      • Grab the cable channel by its base, squeeze, and pull up at the same time to remove it.
      Pergunte ao FixBot
      Comentar
    5. Levoit Core 300-RAC Power Cord Replacement: passo 8, imagem 1 %32 Levoit Core 300-RAC Power Cord Replacement: passo 8, imagem 2 %32
      • Remove the four Phillips #2 screws securing the gray face plate.
      Pergunte ao FixBot
      Comentar
    6. Levoit Core 300-RAC Power Cord Replacement: passo 9, imagem 1 %32 Levoit Core 300-RAC Power Cord Replacement: passo 9, imagem 2 %32 Levoit Core 300-RAC Power Cord Replacement: passo 9, imagem 3 %32
      • Insert a Jimmy or spudger between the white tab and the gray faceplate body to release the faceplate.
      • Lift it out.
      Pergunte ao FixBot
      Comentar
    7. Levoit Core 300-RAC Power Cord Replacement: passo 10, imagem 1 %32
      • Use wire cutters to carefully cut off the crimped power cord connections and remove the white power cord.
      • Cut as close to the connection as possible to leave as much of the internal wires as possible.
      • Cut your new power cable to length and replace the old one. You can splice the new cable on using a soldering iron, heat shrink tubing, and a heat gun. Alternatively, you can use twist-on wire nuts to make a secure connection. For more information on soldering, take a look at How to Solder and Desolder Connectors, and How to Use Heat Shrink Tubing.
      Pergunte ao FixBot
      Comentar
Conclusão
David Kamp
Membro desde: 11/02/23
589 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 1-6, Petersen Fall 2023 Membro de UMass Dartmouth, Team 1-6, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G6
5 Membros
Autoria de 8 guias
2Comentários do guia
You're a lifesaver, thank you! My rabbit managed to reach the cable for mine and chewed it up, my allergies have been going crazy
Grace - Responder Compartilhar
What type of cable did you use to replace the older one?
Mauricio Diaz - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 25
Últimos 30 dias: 101
Ao todo: 3,286
