Ir para o conteúdo principal
Levoit Core 300-RAC Control Board Replacement
O que você precisa
    1. Levoit Core 300-RAC Control Board Replacement, Control Board: passo 1, imagem 1 %32 Levoit Core 300-RAC Control Board Replacement, Control Board: passo 1, imagem 2 %32 Levoit Core 300-RAC Control Board Replacement, Control Board: passo 1, imagem 3 %32
      • Make sure the device is turned off and unplugged before disassembling it.
      • Insert the Jimmy between the gray grille cover and the top of the device.
      • Work your way around the grille cover with the Jimmy to release the clips holding it in place.
      • Take note of the placement of the clips, as they are keyed and need to go back in the exact way they came out.
      • Remove the grille cover gently as it is connected by a ribbon cable.
      • Be careful not to put too much strain on the ribbon cable as it may break.
      Pergunte ao FixBot
      Comentar
    2. Levoit Core 300-RAC Control Board Replacement: passo 2, imagem 1 %32 Levoit Core 300-RAC Control Board Replacement: passo 2, imagem 2 %32 Levoit Core 300-RAC Control Board Replacement: passo 2, imagem 3 %32
      • Squeeze the tab on the connector to release the bundled cable from the control board.
      • The connector should come out fairly easily, so do not force it. Pulling too hard could damage the connector.
      Pergunte ao FixBot
      Comentar
    3. Levoit Core 300-RAC Control Board Replacement: passo 3, imagem 1 %32 Levoit Core 300-RAC Control Board Replacement: passo 3, imagem 2 %32
      • Gently bend the gray plastic cover to release the control board.
      • There are several hard tabs holding the control board in place.
      Pergunte ao FixBot
      Comentar
    4. Levoit Core 300-RAC Control Board Replacement: passo 4, imagem 1 %32 Levoit Core 300-RAC Control Board Replacement: passo 4, imagem 2 %32 Levoit Core 300-RAC Control Board Replacement: passo 4, imagem 3 %32
      • Lift the control board from the gray plastic cover.
      • Take note of the orientations of the buttons, as that will help during reassembly.
      Pergunte ao FixBot
      Comentar
Conclusão
Mustafa
Membro desde: 11/03/23
259 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 1-6, Petersen Fall 2023 Membro de UMass Dartmouth, Team 1-6, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G6
5 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 22
Últimos 30 dias: 92
Ao todo: 1,875
