Introdução
If you are having trouble with your Lenovo Yoga C930-13IKB touch pad or your touch pad is damaged, this guide will help you replace it. First, check out this troubleshooting guide to try other ways to fix a faulty touch pad before replacing it.
To access the touch pad, you will need to remove the back cover and the battery, which is outlined below. Then the back of the touch pad will be exposed and you can take it out once all the fasteners have been removed.
Peças
Nenhum componente especificado.
Flip the device over so that the underside is facing up.
Remove the six 3.5 mm T5 Torx screws.
Unplug the battery from the motherboard by pinching the cables with your fingers and tugging out with force.
Use your fingers to pry up the clear plastic pull-tab for one of the stretch release adhesives.
Grasp the pull-tab and slowly pull away from the battery at a shallow angle. The adhesive strip will stretch to many times its length and slowly release from underneath the battery.
Repeat the procedure for the second strip on the opposite side of the battery.
Remove the battery with your hands.
Uma outra pessoa concluiu este guia.
