Ir para o conteúdo principal
Lenovo Yoga C930-13IKB Power Button Board Replacement
O que você precisa
  1. Lenovo Yoga C930-13IKB Power Button Board Replacement, Back Cover: passo 1, imagem 1 %32
    • Flip the device over so that the underside is facing up.
    • Remove the six 3.5 mm T5 Torx screws.
  2. Lenovo Yoga C930-13IKB Power Button Board Replacement: passo 2, imagem 1 %32 Lenovo Yoga C930-13IKB Power Button Board Replacement: passo 2, imagem 2 %32
    • Pry off the back cover using the plastic opening tool.
    • Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
    • You may have to run the plastic tool along the edges until you find a small gap to separate the back cover from the laptop.
    • Do not use a metal tool when working with your device.
  3. Lenovo Yoga C930-13IKB Power Button Board Replacement: passo 3, imagem 1 %32 Lenovo Yoga C930-13IKB Power Button Board Replacement: passo 3, imagem 2 %32
    • Carefully lift the cover off with your hands.
  4. Lenovo Yoga C930-13IKB Power Button Board Replacement, Battery: passo 4, imagem 1 %32 Lenovo Yoga C930-13IKB Power Button Board Replacement, Battery: passo 4, imagem 2 %32 Lenovo Yoga C930-13IKB Power Button Board Replacement, Battery: passo 4, imagem 3 %32
    • Unplug the battery from the motherboard by pinching the cables with your fingers and tugging out with force.
    • Use the spudger for assistance.
  5. Lenovo Yoga C930-13IKB Power Button Board Replacement: passo 5, imagem 1 %32
    • Unscrew the four 3mm screws with a Phillips screwdriver.
  6. Lenovo Yoga C930-13IKB Power Button Board Replacement: passo 6, imagem 1 %32 Lenovo Yoga C930-13IKB Power Button Board Replacement: passo 6, imagem 2 %32
    • The battery is still held in place with two stretch-release adhesive strips, similar to ones found in an iPhone.
    • Use your fingers to pry up the clear plastic pull-tab for one of the stretch release adhesives.
    • Grasp the pull-tab and slowly pull away from the battery at a shallow angle. The adhesive strip will stretch to many times its length and slowly release from underneath the battery.
    • Repeat the procedure for the second strip on the opposite side of the battery.
    • Be careful not to bend the battery. Breaking the battery is dangerous.
    • Remove the battery with your hands.
  7. Lenovo Yoga C930-13IKB Power Button Board Replacement, SSD: passo 7, imagem 1 %32
    • Remove the screw ( 2 mm with a 5 mm head) that connect the SSD to the motherboard using a Phillips #00 screwdriver.
  8. Lenovo Yoga C930-13IKB Power Button Board Replacement: passo 8, imagem 1 %32
    • Pinch the left side of the SSD card.
    • Pull gently to the left, horizontal to the laptop.
  9. Lenovo Yoga C930-13IKB Power Button Board Replacement, Power Button Board: passo 9, imagem 1 %32 Lenovo Yoga C930-13IKB Power Button Board Replacement, Power Button Board: passo 9, imagem 2 %32 Lenovo Yoga C930-13IKB Power Button Board Replacement, Power Button Board: passo 9, imagem 3 %32
    • Unscrew the two 2mm screws using a Phillips #00 screwdriver.
    • Gently lift out the digital pen spring using the iFixit opening tool.
  10. Lenovo Yoga C930-13IKB Power Button Board Replacement: passo 10, imagem 1 %32 Lenovo Yoga C930-13IKB Power Button Board Replacement: passo 10, imagem 2 %32 Lenovo Yoga C930-13IKB Power Button Board Replacement: passo 10, imagem 3 %32
    • Remove four 2 mm screws from the digital pen holder using a Phillips #00 screwdriver.
    • Do not remove the pen holder until the attached ribbon cable is uninstalled.
  11. Lenovo Yoga C930-13IKB Power Button Board Replacement: passo 11, imagem 1 %32 Lenovo Yoga C930-13IKB Power Button Board Replacement: passo 11, imagem 2 %32
    • Using the angled ESD tweezers, gently lift the black tab on top of the ZIF connector on the motherboard which connects the power button ribbon cable.
    • Gently pull the cable out from the connector.
  12. Lenovo Yoga C930-13IKB Power Button Board Replacement: passo 12, imagem 1 %32 Lenovo Yoga C930-13IKB Power Button Board Replacement: passo 12, imagem 2 %32
    • Carefully lift out the digital pen holder with the attached power button ribbon cable.
  13. Lenovo Yoga C930-13IKB Power Button Board Replacement: passo 13, imagem 1 %32 Lenovo Yoga C930-13IKB Power Button Board Replacement: passo 13, imagem 2 %32 Lenovo Yoga C930-13IKB Power Button Board Replacement: passo 13, imagem 3 %32
    • Depress the power button, then gently pull and detach it using the angled ESD tweezers.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 44
Duração total: 1,524
