Introdução
This guide includes all the steps, tools, and parts necessary to disassemble the Lenovo Yoga C930-13IKB to access and replace the fingerprint reader.
O que você precisa
Flip the device over so that the underside is facing up.
Remove the six 3.5 mm T5 Torx screws.
Unplug the battery from the motherboard by pinching the cables with your fingers and tugging out with force.
Use your fingers to pry up the clear plastic pull-tab for one of the stretch release adhesives.
Grasp the pull-tab and slowly pull away from the battery at a shallow angle. The adhesive strip will stretch to many times its length and slowly release from underneath the battery.
Repeat the procedure for the second strip on the opposite side of the battery.
Remove the battery with your hands.
Remove the single 2 mm screw from the fingerprint reader cover plate using the Phillips #00 screwdriver.
Gently lift and slide out the cover plate using a pair of angled ESD tweezers.
