Ir para o conteúdo principal
Lenovo Yoga 900-13ISK Solid State Drive Replacement
O que você precisa
  1. Lenovo Yoga 900-13ISK Solid State Drive Replacement, Back Cover: passo 1, imagem 1 %32 Lenovo Yoga 900-13ISK Solid State Drive Replacement, Back Cover: passo 1, imagem 2 %32
    • Using a T5 Torx screwdriver, remove the ten 5.5 mm screws from the back case of the laptop.
  2. Lenovo Yoga 900-13ISK Solid State Drive Replacement: passo 2, imagem 1 %32 Lenovo Yoga 900-13ISK Solid State Drive Replacement: passo 2, imagem 2 %32 Lenovo Yoga 900-13ISK Solid State Drive Replacement: passo 2, imagem 3 %32
    • Use a spudger to pry open the back case at the hinges of the laptop.
    • There are plastic clips around the perimeter of the case holding down the back cover. These will need to be popped off as the cover is removed.
    • Use your fingers to completely pop off the back cover.
  3. Lenovo Yoga 900-13ISK Solid State Drive Replacement, Battery: passo 3, imagem 1 %32 Lenovo Yoga 900-13ISK Solid State Drive Replacement, Battery: passo 3, imagem 2 %32 Lenovo Yoga 900-13ISK Solid State Drive Replacement, Battery: passo 3, imagem 3 %32
    • Remove the five 3.6 mm screws from the battery with a Phillips #00 screwdriver.
  4. Lenovo Yoga 900-13ISK Solid State Drive Replacement: passo 4, imagem 1 %32 Lenovo Yoga 900-13ISK Solid State Drive Replacement: passo 4, imagem 2 %32 Lenovo Yoga 900-13ISK Solid State Drive Replacement: passo 4, imagem 3 %32
    • Grab the bottom corners of the battery and gently pull the battery until the cable disconnects from the connector on the motherboard.
    • While reassembling, use a plastic spudger to push the battery cable into the connector on the underside of the motherboard. This will be easier to do before the screws are replaced.
  5. Lenovo Yoga 900-13ISK Solid State Drive Replacement, Solid State Drive: passo 5, imagem 1 %32 Lenovo Yoga 900-13ISK Solid State Drive Replacement, Solid State Drive: passo 5, imagem 2 %32 Lenovo Yoga 900-13ISK Solid State Drive Replacement, Solid State Drive: passo 5, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove the 2.7 mm screw that is holding down the SSD card.
  6. Lenovo Yoga 900-13ISK Solid State Drive Replacement: passo 6, imagem 1 %32 Lenovo Yoga 900-13ISK Solid State Drive Replacement: passo 6, imagem 2 %32 Lenovo Yoga 900-13ISK Solid State Drive Replacement: passo 6, imagem 3 %32
    • Pull the SSD card out of the port to the right.
Conclusão
Uma outra pessoa concluiu este guia.
Austin Blakely
Membro desde: 03/11/19
21.298 Reputação
Autoria de 53 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.527 guias
2 comentários
seem you just inserted 512 GB nVMe SSD for lenova yoga 900 ISK, does it ever worked out… ?
Because this 13 ISK ( with i7, 6500U core) is the first generation and can only seem support SATA m.2 SSD, not NVMe SSD as you one inserted to slot.
Many user, technicains etc, They claim Bios for earlier version( first yoga 900, with i7 6500 U) doesn’t have firmware to recognize NVMe SSDs. But 13 ISK2 version may work with NVMe SSD!
So your BİOS ( for lenova yoga 900 13 ISK, i7 6500 U core) recognize and accepts only SATA III, m.2. SSD ( like Samsung eve 860 Sata III, M2. SSD or WD….sata III, M.2 SSD..so on, etc). Besides Lenovo yoga 13 ISK ( earlier, first generation with i7, 6500 u chip) the SLOT for this has 2 notch ( suitable for SATA III, M.2. SSD)…
Hawk Eni - Responder
Hi Hawk. I have an issue with yoga 900 13 ISK. I am trying to upgrade the m.2. SSD disk from 512gb to 1tb. I want to know if that is possible.
Regards
Patricio Naranjo -
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 52
Ao todo: 3,535
