Ir para o conteúdo principal
Lenovo Yoga 720-15IKB Fan Replacement
O que você precisa
  1. Lenovo Yoga 720-15IKB Fan Replacement, Bottom Cover: passo 1, imagem 1 %32 Lenovo Yoga 720-15IKB Fan Replacement, Bottom Cover: passo 1, imagem 2 %32 Lenovo Yoga 720-15IKB Fan Replacement, Bottom Cover: passo 1, imagem 3 %32
    • Power off the device before starting.
    • Flip the device over with the hinges facing away from you.
    • Remove seven 5.0 mm Torx T5 screws.
    • Remove three 9.5 mm Torx T5 screws.
  2. Lenovo Yoga 720-15IKB Fan Replacement: passo 2, imagem 1 %32 Lenovo Yoga 720-15IKB Fan Replacement: passo 2, imagem 2 %32
    • Pry around the edges from one side to another with a plastic opening tool.
    • Do not pry on the side with the hinges because this can break the cover.
    • Lift the case from the front until you feel resistance.
    • Do not keep lifting after you feel resistance, or the bottom cover can break.
    • Pull the cover towards you, away from the hinges.
    • Completely lift off the cover.
  3. Lenovo Yoga 720-15IKB Fan Replacement, Fan: passo 3, imagem 1 %32 Lenovo Yoga 720-15IKB Fan Replacement, Fan: passo 3, imagem 2 %32
    • Remove the six 5.2mm Torx T5 screws holding the fan in place.
    • Remove the five 5.0mm Torx T5 screws holding the fan in place.
  4. Lenovo Yoga 720-15IKB Fan Replacement: passo 4, imagem 1 %32 Lenovo Yoga 720-15IKB Fan Replacement: passo 4, imagem 2 %32 Lenovo Yoga 720-15IKB Fan Replacement: passo 4, imagem 3 %32
    • Disconnect the two fan wire connectors.
    • Firmly pull the connector out horizontally away from the socket.
    • Carefully lift the fan up and out.
Conclusão
6 outras pessoas executaram este guia.
Shaina Bagri
Membro desde: 01/23/20
447 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S19-G3, White Winter 2020 Membro de Cal Poly, Team S19-G3, White Winter 2020
CPSU-WHITE-W20S19G3
Membros da 4
Autoria de 25 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 39
Duração total: 3,596
