Introdução
The Lenovo Yoga 710-11ISK’s hinges are fairly important as they allow the display to be opened up and allow the computer to function similar to a tablet. This guide shows how to disassemble the computer in order to access the hinges and replace them.
O que você precisa
Remove the eleven screws that secure the bottom panel using a T5 Torx screwdriver.
Wedge an opening tool between the display and display housing, then slide the opening tool around the perimeter of the display while gently prying until the display releases.
Remove the screw covers located near the hinges on the display side using an opening tool.
Remove the cover panel between the screw covers using an opening tool.
