Ir para o conteúdo principal
Lenovo Yoga 710-11ISK Hinge Replacement
O que você precisa
  1. Lenovo Yoga 710-11ISK Hinge Replacement, Hinge: passo 1, imagem 1 %32
    • Remove the eleven screws that secure the bottom panel using a T5 Torx screwdriver.
  2. Lenovo Yoga 710-11ISK Hinge Replacement: passo 2, imagem 1 %32
    • Insert an opening tool between the bottom panel and chassis, then pry around the entire perimeter until the five clips detach, releasing the bottom panel.
  3. Lenovo Yoga 710-11ISK Hinge Replacement: passo 3, imagem 1 %32
    • Use a Phillips #000 screwdriver to remove the ten black screws on the two hinge brackets.
  4. Lenovo Yoga 710-11ISK Hinge Replacement: passo 4, imagem 1 %32 Lenovo Yoga 710-11ISK Hinge Replacement: passo 4, imagem 2 %32 Lenovo Yoga 710-11ISK Hinge Replacement: passo 4, imagem 3 %32
    • Wedge an opening tool between the display and display housing, then slide the opening tool around the perimeter of the display while gently prying until the display releases.
    • Remove the screw covers located near the hinges on the display side using an opening tool.
    • Remove the cover panel between the screw covers using an opening tool.
  5. Lenovo Yoga 710-11ISK Hinge Replacement: passo 5, imagem 1 %32
    • Remove the screws securing the hinge brackets with a Phillips #000 screwdriver.
    • Remove the plastic cover that holds the wires in place.
  6. Lenovo Yoga 710-11ISK Hinge Replacement: passo 6, imagem 1 %32 Lenovo Yoga 710-11ISK Hinge Replacement: passo 6, imagem 2 %32 Lenovo Yoga 710-11ISK Hinge Replacement: passo 6, imagem 3 %32
    • Disconnect the black and white wires from the sides of the display.
    • Disconnect the orange ribbon cable.
    • Remove the tape, covers, and stickers that hold in the components.
  7. Lenovo Yoga 710-11ISK Hinge Replacement: passo 7, imagem 1 %32 Lenovo Yoga 710-11ISK Hinge Replacement: passo 7, imagem 2 %32
    • Soldering/desoldering presents potential for device damage and burns. Always solder/desolder in a well-ventilated environment.
    • Use a soldering iron to disconnect the ends of both wires that are embedded into the display.
    • Remove the hinges and their components from the computer.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 33
Duração total: 895
