Ir para o conteúdo principal
Lenovo Yoga 6 13ALC6 Lower Case Replacement
O que você precisa
  1. Lenovo Yoga 6 13ALC6 Lower Case Replacement, Unfasten the lower case: passo 1, imagem 1 %32 Lenovo Yoga 6 13ALC6 Lower Case Replacement, Unfasten the lower case: passo 1, imagem 2 %32
    • Use a T5 Torx screwdriver to remove the six 7.2 mm screws securing the lower case.
  2. Lenovo Yoga 6 13ALC6 Lower Case Replacement, Insert the opening pick: passo 2, imagem 1 %32 Lenovo Yoga 6 13ALC6 Lower Case Replacement, Insert the opening pick: passo 2, imagem 2 %32
    • Insert an opening pick between the lower case and the chassis at a hinge corner.
    • Pry up with the pick to release the clips securing the lower case.
    • Repeat the process on the other hinge corner.
  3. Lenovo Yoga 6 13ALC6 Lower Case Replacement, Release the clips: passo 3, imagem 1 %32 Lenovo Yoga 6 13ALC6 Lower Case Replacement, Release the clips: passo 3, imagem 2 %32 Lenovo Yoga 6 13ALC6 Lower Case Replacement, Release the clips: passo 3, imagem 3 %32
    • Slide the pick along the right edge to release the clips securing the lower case.
  4. Lenovo Yoga 6 13ALC6 Lower Case Replacement, Release the remaining clips: passo 4, imagem 1 %32 Lenovo Yoga 6 13ALC6 Lower Case Replacement, Release the remaining clips: passo 4, imagem 2 %32 Lenovo Yoga 6 13ALC6 Lower Case Replacement, Release the remaining clips: passo 4, imagem 3 %32
    • Continue sliding the opening pick along the front and left edges to release the remaining clips.
  5. Lenovo Yoga 6 13ALC6 Lower Case Replacement: passo 5, imagem 1 %32 Lenovo Yoga 6 13ALC6 Lower Case Replacement: passo 5, imagem 2 %32 Lenovo Yoga 6 13ALC6 Lower Case Replacement: passo 5, imagem 3 %32
    • Insert the pick on the hinge edge and slide along the entire edge to release all of the clips.
  6. Lenovo Yoga 6 13ALC6 Lower Case Replacement: passo 6, imagem 1 %32 Lenovo Yoga 6 13ALC6 Lower Case Replacement: passo 6, imagem 2 %32 Lenovo Yoga 6 13ALC6 Lower Case Replacement: passo 6, imagem 3 %32
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
Conclusão
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Lenovo Yoga answers community for help.
Spencer Day
Membro desde: 09/14/22
55.203 Reputação
Autoria de 408 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.430 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 16
Últimos 30 dias: 74
Duração total: 1,382
