Ir para o conteúdo principal
Lenovo Yoga 3 Pro USB Ports Replacement
O que você precisa
  1. Lenovo Yoga 3 Pro USB Ports Replacement, Battery: passo 1, imagem 1 %32
    • Before opening your laptop, make sure it is powered off.
    • Remove the ten 3.3 mm screws from the base cover using a T5 Torx screwdriver.
    Pergunte ao FixBot
  2. Lenovo Yoga 3 Pro USB Ports Replacement: passo 2, imagem 1 %32
    • Slide the plastic opening tool between the base cover and the frame to pry open the computer.
    • Slowly go around the entire perimeter of the computer until all edges are loose.
    • Make sure the plastic opening tool doesn't go too far into the device.
    Pergunte ao FixBot
  3. Lenovo Yoga 3 Pro USB Ports Replacement: passo 3, imagem 1 %32
    • Remove the panel and place it in a safe location.
    Pergunte ao FixBot
  4. Lenovo Yoga 3 Pro USB Ports Replacement: passo 4, imagem 1 %32
    • Remove the six 3.5 mm screws surrounding the battery using a Phillips 00 screwdriver.
    Pergunte ao FixBot
  5. Lenovo Yoga 3 Pro USB Ports Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
    Pergunte ao FixBot
  6. Lenovo Yoga 3 Pro USB Ports Replacement: passo 6, imagem 1 %32
    • Carefully lift and remove the battery.
    Pergunte ao FixBot
  7. Lenovo Yoga 3 Pro USB Ports Replacement, Speakers: passo 7, imagem 1 %32
    • Remove the four 4 mm screws using the Phillips 00 screwdriver.
    Pergunte ao FixBot
  8. Lenovo Yoga 3 Pro USB Ports Replacement: passo 8, imagem 1 %32 Lenovo Yoga 3 Pro USB Ports Replacement: passo 8, imagem 2 %32
    • Using the plastic opening tool, flip open tab as shown.
    Pergunte ao FixBot
  9. Lenovo Yoga 3 Pro USB Ports Replacement: passo 9, imagem 1 %32 Lenovo Yoga 3 Pro USB Ports Replacement: passo 9, imagem 2 %32 Lenovo Yoga 3 Pro USB Ports Replacement: passo 9, imagem 3 %32
    • Remove the adhesive tape.
    • Flip open the ribbon connecting tab.
    • Carefully lift the ribbon connector from its adhesive.
    Pergunte ao FixBot
  10. Lenovo Yoga 3 Pro USB Ports Replacement: passo 10, imagem 1 %32 Lenovo Yoga 3 Pro USB Ports Replacement: passo 10, imagem 2 %32
    • Remove the speaker and set it on the side.
    • Use the plastic opening tool to remove the cables.
    • Be careful of other cables.
    Pergunte ao FixBot
  11. Lenovo Yoga 3 Pro USB Ports Replacement: passo 11, imagem 1 %32 Lenovo Yoga 3 Pro USB Ports Replacement: passo 11, imagem 2 %32
    • Removing the other speaker by unwinding cables.
    • Lift both speakers carefully.
    Pergunte ao FixBot
  12. Lenovo Yoga 3 Pro USB Ports Replacement, USB Ports: passo 12, imagem 1 %32 Lenovo Yoga 3 Pro USB Ports Replacement, USB Ports: passo 12, imagem 2 %32
    • Use the plastic opening tool to flip open the tab on each ribbon connector as shown.
    • Ribbon connectors can be fragile, so be gentle when disconnecting them.
    Pergunte ao FixBot
  13. Lenovo Yoga 3 Pro USB Ports Replacement: passo 13, imagem 1 %32
    • Remove the three indicated 3.5 mm screws using the Philips 00 screwdriver.
    Pergunte ao FixBot
  14. Lenovo Yoga 3 Pro USB Ports Replacement: passo 14, imagem 1 %32
    • Remove the USB assembly.
    • If this is the side that was not working, then follow the steps backwards from here to put it back together.
    Pergunte ao FixBot
  15. Lenovo Yoga 3 Pro USB Ports Replacement: passo 15, imagem 1 %32
    • On the other side of the laptop, remove the two 3.5 mm screws using the Philips 00 screwdriver.
    Pergunte ao FixBot
  16. Lenovo Yoga 3 Pro USB Ports Replacement: passo 16, imagem 1 %32
    • Remove the two 2.5 mm screws using the Philips 00 screwdriver.
    Pergunte ao FixBot
  17. Lenovo Yoga 3 Pro USB Ports Replacement: passo 17, imagem 1 %32
    • Use the plastic opening tool to lift the metal cable holders.
    • Exercise caution. Cable holders will break if lifted too far.
    Pergunte ao FixBot
  18. Lenovo Yoga 3 Pro USB Ports Replacement: passo 18, imagem 1 %32
    • Lift the USB port up and use the plastic opening tool to loop the wires around the USB port.
    Pergunte ao FixBot
  19. Lenovo Yoga 3 Pro USB Ports Replacement: passo 19, imagem 1 %32
    • Remove the USB assembly using the plastic opening tool.
    Pergunte ao FixBot
  20. Lenovo Yoga 3 Pro USB Ports Replacement: passo 20, imagem 1 %32
    • Disconnect the WiFi card from the USB assembly.
    • Be careful with the connectors on the WiFi card as they are fragile.
    Pergunte ao FixBot
  21. Lenovo Yoga 3 Pro USB Ports Replacement: passo 21, imagem 1 %32
    • Pull the second USB hub off.
    • Be careful when pulling out the cable.
    Pergunte ao FixBot
Conclusão
11 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 12-17, Maness Fall 2015 Membro de Cal Poly, Team 12-17, Maness Fall 2015
CPSU-MANESS-F15S12G17
4 Membros
Autoria de 15 guias
4Comentários do guia
Repaired customers Yoga 3 that had NO working USB ports whatsoever in less than an hour - after cleaning & replacing (no parts needed)
All USB ports were fully functional once again...
Great job & thank you for the help :)
admin - Responder Compartilhar
This guide helped me quite a bit today. I really appreciate you providing it.
Jon Tucich - Responder Compartilhar
Can you please help with information on where to get the DC input USB port part. My USB port is broken and unable to find it
Dheeraj - Responder Compartilhar
None of the 3 USB ports were powering on.
Windows seemed happy and no drivers and bios update helped …
I took apart following this guide, cleaned all ports and PCBs with IPA and a toothbrush and now it’s all working again!
Thank you
ori elyada - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 69
Ao todo: 14,257
