Ir para o conteúdo principal
Lenovo Yoga 3 Pro Battery Replacement
O que você precisa
  1. Lenovo Yoga 3 Pro Battery Replacement, Battery: passo 1, imagem 1 %32
    • Before opening your laptop, make sure it is powered off.
    • Remove the ten 3.3 mm screws from the base cover using a T5 Torx screwdriver.
  2. Lenovo Yoga 3 Pro Battery Replacement: passo 2, imagem 1 %32
    • Slide the plastic opening tool between the base cover and the frame to pry open the computer.
    • Slowly go around the entire perimeter of the computer until all edges are loose.
    • Make sure the plastic opening tool doesn't go too far into the device.
  3. Lenovo Yoga 3 Pro Battery Replacement: passo 3, imagem 1 %32
    • Remove the panel and place it in a safe location.
  4. Lenovo Yoga 3 Pro Battery Replacement: passo 4, imagem 1 %32
    • Remove the six 3.5 mm screws surrounding the battery using a Phillips 00 screwdriver.
  5. Lenovo Yoga 3 Pro Battery Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
  6. Lenovo Yoga 3 Pro Battery Replacement: passo 6, imagem 1 %32
    • Carefully lift and remove the battery.
Conclusão
26 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 12-17, Maness Fall 2015 Membro de Cal Poly, Team 12-17, Maness Fall 2015
CPSU-MANESS-F15S12G17
Membros da 4
Autoria de 15 guias
8 comentários
Very good and very easy to understand
barri.smith - Responder
Your really good love watching how you take apart Samsung S5 me I want to take out my mother board
and replace it with a motherboard that recognizes Optus and also download the firmware which it cannot do right now
had it repaired stuffed the phone right up so not sure if I can do this as good as you have the tools
Raewyn Dowd - Responder
does this same process work for a lonovo yoga pro 2?
Abi Alexander - Responder
Awesome and simple! Thank you!
Hong K. Nguyen - Responder
I have changed my battery and it won't turn on. I followed all the steps and the changing light won't even light up. My laptop with the old battery was working (only when connected). Not sure what to do next?
Erika
Erika Mackintosh - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 16
Últimos 30 dias: 81
Duração total: 60,544
