Ir para o conteúdo principal
Lenovo Y50 Touch RAM Replacement
O que você precisa
  1. Lenovo Y50 Touch RAM Replacement, RAM: passo 1, imagem 1 %32 Lenovo Y50 Touch RAM Replacement, RAM: passo 1, imagem 2 %32
    • Place laptop on a flat surface with the back cover facing up.
    • Remove all twelve 6 mm long screws on the back of the laptop using a Phillips #1 screwdriver.
    • Apply a lot of pressure to prevent the screws from stripping.
    Pergunte ao FixBot
    Comentar
  2. Lenovo Y50 Touch RAM Replacement: passo 2, imagem 1 %32 Lenovo Y50 Touch RAM Replacement: passo 2, imagem 2 %32
    • Gently pull off the back cover of the laptop. It should come off easily.
    Pergunte ao FixBot
    Comentar
  3. Lenovo Y50 Touch RAM Replacement, Locate the RAM: passo 3, imagem 1 %32
    • The RAM should be located at the indicated area inside the laptop.
    Pergunte ao FixBot
    Comentar
  4. Lenovo Y50 Touch RAM Replacement, Unclamp the RAM: passo 4, imagem 1 %32 Lenovo Y50 Touch RAM Replacement, Unclamp the RAM: passo 4, imagem 2 %32
    • Release the clamps securing the RAM by pushing each clamp away from the RAM.
    • Once the clamps are released, the RAM should be facing outward at an angle.
    Pergunte ao FixBot
    Comentar
  5. Lenovo Y50 Touch RAM Replacement, Remove the RAM: passo 5, imagem 1 %32 Lenovo Y50 Touch RAM Replacement, Remove the RAM: passo 5, imagem 2 %32 Lenovo Y50 Touch RAM Replacement, Remove the RAM: passo 5, imagem 3 %32
    • Gently unplug the RAM from its port.
    • Do not bend or drop the RAM, as this can affect its function.
    • You can replace up to two RAM sticks for this laptop. Just repeat step 4 for the second RAM port.
    • Pay attention to the arrangement of the pins on the RAM. When replacing the RAM, make sure the pins line up with the pins on the RAM port.
    Pergunte ao FixBot
    Comentar
Conclusão
9 outras pessoas executaram este guia.
Andrew Tran
Membro desde: 01/21/15
820 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 18-1, Maness Winter 2015 Membro de Cal Poly, Team 18-1, Maness Winter 2015
CPSU-MANESS-W15S18G1
5 Membros
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 34
Ao todo: 5,825
