Introdução
If your Lenovo V14-ADA laptop (model 82C60072UE) has sticky keys or keys that aren't working when you try typing, use this guide to replace any individual key that needs to be fixed.
The individual keys on a keyboard work together to allow one to type on a laptop. Faulty keys or stuck keys can cause some keys to not type properly.
O que você precisa
Place the flat edge of a spudger under the key, and push slightly to pop it off.
1Comentário do guia
One thing this guide doesn't mention: there are three different scissor retainer clip styles across Lenovo models, and they're not interchangeable. The V14-ADA uses a dual-post style — if you order a butterfly clip by mistake it won't seat correctly. You can identify which you have by looking at the tab shapes in the empty socket (rectangular tabs = dual-post, angled/curved tabs = butterfly). Worth confirming before ordering. I got my replacement parts from laptop-keys.com by searching the model number — they have a clip-type filter that helped me avoid getting the wrong one.
