Ir para o conteúdo principal
Lenovo ThinkPad x120e LCD Screen Replacement
O que você precisa
  1. Lenovo ThinkPad x120e LCD Screen Replacement, Battery: passo 1, imagem 1 %32 Lenovo ThinkPad x120e LCD Screen Replacement, Battery: passo 1, imagem 2 %32
    • Flip the laptop upside down and locate the battery latches under the battery.
    • Place your thumbs on both latches and push the latch inwards.
    • With your thumbs still on the latches, slide the battery out of the laptop.
    • To install a new battery, simply slide the battery back in the slot. Then, check if both battery latches are locked
  2. Lenovo ThinkPad x120e LCD Screen Replacement, Back Cover: passo 2, imagem 1 %32 Lenovo ThinkPad x120e LCD Screen Replacement, Back Cover: passo 2, imagem 2 %32 Lenovo ThinkPad x120e LCD Screen Replacement, Back Cover: passo 2, imagem 3 %32
    • Using the Phillips #0 screwdriver, remove the three 4 mm screws that are securing the bottom cover.
    • Remove the backplate carefully, making sure not to bend the cover.
  3. Lenovo ThinkPad x120e LCD Screen Replacement, Keyboard: passo 3, imagem 1 %32 Lenovo ThinkPad x120e LCD Screen Replacement, Keyboard: passo 3, imagem 2 %32
    • Using the Phillips #0 screwdriver, remove the two 4 mm retaining screws located on the battery slot.
  4. Lenovo ThinkPad x120e LCD Screen Replacement: passo 4, imagem 1 %32 Lenovo ThinkPad x120e LCD Screen Replacement: passo 4, imagem 2 %32 Lenovo ThinkPad x120e LCD Screen Replacement: passo 4, imagem 3 %32
    • Flip the laptop back over, showing the keyboard.
    • Using an opening tool, pry open the keyboard starting from the top left. Work your way around until you are able to loosely lift the keyboard.
    • You should see two ribbon wires located beneath the keyboard once you are done.
  5. Lenovo ThinkPad x120e LCD Screen Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad x120e LCD Screen Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Pull on the black tabs above both ribbon wires using tweezers upwards.
    • For more information on Zero Insertion Force (ZIF) connectors, please visit this guide.
    • Remove both ribbon wires.
    • Remove the keyboard from the laptop.
  6. Lenovo ThinkPad x120e LCD Screen Replacement, LCD Screen: passo 6, imagem 1 %32 Lenovo ThinkPad x120e LCD Screen Replacement, LCD Screen: passo 6, imagem 2 %32
    • Remove the screw covers that are located on both sides of the display using a spudger.
    • Start from the corners of the screw covers to remove it more easily.
  7. Lenovo ThinkPad x120e LCD Screen Replacement: passo 7, imagem 1 %32
    • Using the Phillips #1 screwdriver, remove the two 4 mm screws.
  8. Lenovo ThinkPad x120e LCD Screen Replacement: passo 8, imagem 1 %32
    • Pry open the frame of the laptop screen using a spudger.
    • Do not try to pry it open from the inside edge of the frame. You may accidentaly damage the screen.
  9. Lenovo ThinkPad x120e LCD Screen Replacement: passo 9, imagem 1 %32
    • Using the Phillips #1 screwdriver, remove six screws securing the screen to the device.
  10. Lenovo ThinkPad x120e LCD Screen Replacement: passo 10, imagem 1 %32 Lenovo ThinkPad x120e LCD Screen Replacement: passo 10, imagem 2 %32
    • Lift up the screen from the top. You should now notice the metal frame.
    • Using the same Phillips #1 screwdriver, remove four screws, two on each edge of the metal frame.
    • The second picture is rotated 90 degrees.
  11. Lenovo ThinkPad x120e LCD Screen Replacement: passo 11, imagem 1 %32
    • Remove the connector on top of the webcam by simply pulling it out.
  12. Lenovo ThinkPad x120e LCD Screen Replacement: passo 12, imagem 1 %32 Lenovo ThinkPad x120e LCD Screen Replacement: passo 12, imagem 2 %32
    • Flip the screen over.
    • Peel the black tape first, then peel the gray tape down to the base of the screen.
  13. Lenovo ThinkPad x120e LCD Screen Replacement: passo 13, imagem 1 %32
    • At the base of the screen, there is a transparent tape holding a connector. Peel the tape off.
  14. Lenovo ThinkPad x120e LCD Screen Replacement: passo 14, imagem 1 %32
    • Remove the connector underneath where the tape was using a spudger tool.
    • Pull out the connector.
    • Make sure to not damage any of the wires.
  15. Lenovo ThinkPad x120e LCD Screen Replacement: passo 15, imagem 1 %32
    • Remove the gray tape fully.
    • Flip over the device, and remove the LCD screen fully.
Conclusão
Jacob Fronzaglia
Membro desde: 10/25/21
787 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team 3-4, Sinclaire Fall 2021 Membro de UMass Dartmouth, Team 3-4, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G4
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 212
