Ir para o conteúdo principal
Lenovo ThinkPad Yoga Keyboard Replacement
O que você precisa
    1. Lenovo ThinkPad Yoga Keyboard Replacement, Battery: passo 1, imagem 1 %32 Lenovo ThinkPad Yoga Keyboard Replacement, Battery: passo 1, imagem 2 %32 Lenovo ThinkPad Yoga Keyboard Replacement, Battery: passo 1, imagem 3 %32
      • Flip the laptop over so the bottom is facing you.
      • Remove the ten screws using a Phillips #1 screwdriver.
      • Using the plastic opening tool, pry the bottom cover off the laptop.
      Pergunte ao FixBot
      Comentar
    2. Lenovo ThinkPad Yoga Keyboard Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad Yoga Keyboard Replacement: passo 2, imagem 2 %32 Lenovo ThinkPad Yoga Keyboard Replacement: passo 2, imagem 3 %32
      • Remove two screws from the battery using a Phillips #1 screwdriver.
      • Disconnect the battery connector from the motherboard.
      • Remove the battery from the laptop.
      Pergunte ao FixBot
      Comentar
    1. Lenovo ThinkPad Yoga Keyboard Replacement, Speakers: passo 3, imagem 1 %32 Lenovo ThinkPad Yoga Keyboard Replacement, Speakers: passo 3, imagem 2 %32 Lenovo ThinkPad Yoga Keyboard Replacement, Speakers: passo 3, imagem 3 %32
      • Disconnect connectors. Use fingers to pinch and pull the connector out.
      Pergunte ao FixBot
      Comentar
    1. Lenovo ThinkPad Yoga Keyboard Replacement, Fan: passo 4, imagem 1 %32 Lenovo ThinkPad Yoga Keyboard Replacement, Fan: passo 4, imagem 2 %32 Lenovo ThinkPad Yoga Keyboard Replacement, Fan: passo 4, imagem 3 %32
      • Remove the two screws from the retainer for the ports using a Phillips #1 screwdriver.
      • Remove the nine screws from the motherboard using a Phillips #1 screwdriver.
      • Remove the four screws from the fan under the motherboard using a Phillips #1 screwdriver.
      • Remove the fan from the motherboard.
      Pergunte ao FixBot
      Comentar
    1. Lenovo ThinkPad Yoga Keyboard Replacement, Keyboard: passo 5, imagem 1 %32
      • Remove twelve screws from the midframe using a Phillips #1 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Lenovo ThinkPad Yoga Keyboard Replacement: passo 6, imagem 1 %32
      • Use a spudger to pry open the keyboard panel.
      • Continue to pry until the panel is loose enough to take off.
      Pergunte ao FixBot
      Comentar
    3. Lenovo ThinkPad Yoga Keyboard Replacement: passo 7, imagem 1 %32
      • Remove the keyboard from the laptop.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021 Membro de UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G4
3 Membros
Autoria de 42 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 35
Últimos 30 dias: 150
Ao todo: 11,712
