Ir para o conteúdo principal
Lenovo ThinkPad X395 SSD Replacement
O que você precisa
  1. Lenovo ThinkPad X395 SSD Replacement, Loosen the back screws: passo 1, imagem 1 %32 Lenovo ThinkPad X395 SSD Replacement, Loosen the back screws: passo 1, imagem 2 %32
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Phillips #1 screwdriver to fully loosen the five screws on the back cover.
    • These are captive screws—they won't come out after being loosened.
  2. Lenovo ThinkPad X395 SSD Replacement, Release the clips: passo 2, imagem 1 %32 Lenovo ThinkPad X395 SSD Replacement, Release the clips: passo 2, imagem 2 %32
    • Orient your laptop so that the screen's silver hinges are closest to you.
    • Insert an opening pick between the back cover and the device body near a hinge corner.
    • Pry upward to release the retaining clips. Listen for a loud click when each clip releases.
  3. Lenovo ThinkPad X395 SSD Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad X395 SSD Replacement: passo 3, imagem 2 %32
    • Insert the opening pick between the back cover and the device body at the other hinge corner.
    • Pry upward on the cover to release additional clips.
  4. Lenovo ThinkPad X395 SSD Replacement, Remove the back cover: passo 4, imagem 1 %32 Lenovo ThinkPad X395 SSD Replacement, Remove the back cover: passo 4, imagem 2 %32 Lenovo ThinkPad X395 SSD Replacement, Remove the back cover: passo 4, imagem 3 %32
    • Lift and remove the cover up from the laptop, starting with the edge nearest to you.
    • Shift the cover side to side if the center clip feels stuck.
    • The cover will hinge open before completely separating from the rest of the laptop.
  5. Lenovo ThinkPad X395 SSD Replacement, Disconnect the battery cable: passo 5, imagem 1 %32 Lenovo ThinkPad X395 SSD Replacement, Disconnect the battery cable: passo 5, imagem 2 %32
    • Grab the battery pull-tab on the head of the connector.
    • Pull the connector out of its socket in the direction of the cable.
  6. Lenovo ThinkPad X395 SSD Replacement, Remove the SSD screw: passo 6, imagem 1 %32 Lenovo ThinkPad X395 SSD Replacement, Remove the SSD screw: passo 6, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the 2.8 mm-long screw holding the SSD in place.
  7. Lenovo ThinkPad X395 SSD Replacement, Remove the SSD by hand: passo 7, imagem 1 %32 Lenovo ThinkPad X395 SSD Replacement, Remove the SSD by hand: passo 7, imagem 2 %32 Lenovo ThinkPad X395 SSD Replacement, Remove the SSD by hand: passo 7, imagem 3 %32
    • Pull the SSD out and away from its socket.
    • If this motion requires excessive force, walk the SSD side to side as you pull.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo ThinkPad answers community for help.
Uma outra pessoa concluiu este guia.
Clay Eickemeyer
Membro desde: 09/19/22
95.775 Reputação
Autoria de 466 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 48
Últimos 30 dias: 179
Ao todo: 6,904
