Ir para o conteúdo principal
Lenovo ThinkPad X390 Battery Replacement
O que você precisa
  1. Lenovo ThinkPad X390 Battery Replacement, Back Cover: passo 1, imagem 1 %32
    • Turn off and power down the laptop before proceeding with the guide.
    • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
    • Using a Phillips #0 screwdriver, unscrew the five screws on the base cover.
    • The screws are not removable.
  2. Lenovo ThinkPad X390 Battery Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad X390 Battery Replacement: passo 2, imagem 2 %32
    • Remove the base cover by inserting a plastic opening tool in between the cover and the rest of the laptop.
    • Once the tool is inserted, slide the tool along the edges of the case and push down on the opening tool to detach the case.
    • You may need to move the tool to different locations to fully release the back cover.
  3. Lenovo ThinkPad X390 Battery Replacement, Battery: passo 3, imagem 1 %32 Lenovo ThinkPad X390 Battery Replacement, Battery: passo 3, imagem 2 %32
    • Using tweezers, unplug the battery from the laptops motherboard by pulling on the cable that attaches it.
  4. Lenovo ThinkPad X390 Battery Replacement: passo 4, imagem 1 %32 Lenovo ThinkPad X390 Battery Replacement: passo 4, imagem 2 %32
    • Using a Phillips #0 screwdriver, remove the four 5.2 mm screws holding the battery in place.
  5. Lenovo ThinkPad X390 Battery Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad X390 Battery Replacement: passo 5, imagem 2 %32
    • Using your hands, remove the battery from the laptop.
Conclusão
For optimal performance, after completing this guide, calibrate your newly installed battery.
Curtis Kubacka
Membro desde: 09/28/21
261 Reputação
Autoria de 2 guias
Equipe
Clemson, Team 5-1, Hunter Fall 2021 Membro de Clemson, Team 5-1, Hunter Fall 2021
CLEM-HUNTER-F21S5G1
Membros da 5
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 49
Últimos 30 dias: 212
Duração total: 3,856
