Ir para o conteúdo principal
Lenovo ThinkPad X280 Speaker Replacement
O que você precisa
  1. Lenovo ThinkPad X280 Speaker Replacement, Back Panel: passo 1, imagem 1 %32
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
  2. Lenovo ThinkPad X280 Speaker Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad X280 Speaker Replacement: passo 2, imagem 2 %32
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
  3. Lenovo ThinkPad X280 Speaker Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad X280 Speaker Replacement: passo 3, imagem 2 %32
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
  4. Lenovo ThinkPad X280 Speaker Replacement, Battery: passo 4, imagem 1 %32 Lenovo ThinkPad X280 Speaker Replacement, Battery: passo 4, imagem 2 %32 Lenovo ThinkPad X280 Speaker Replacement, Battery: passo 4, imagem 3 %32
    • Using the Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery down.
    • Remove the battery.
  5. Lenovo ThinkPad X280 Speaker Replacement, Speakers: passo 5, imagem 1 %32 Lenovo ThinkPad X280 Speaker Replacement, Speakers: passo 5, imagem 2 %32 Lenovo ThinkPad X280 Speaker Replacement, Speakers: passo 5, imagem 3 %32
    • Using a Phillips #1 screwdriver, remove two 5 mm screws from each speaker.
    • Once done, the speakers should still be attached with a red wire connecting to each other.
  6. Lenovo ThinkPad X280 Speaker Replacement: passo 6, imagem 1 %32 Lenovo ThinkPad X280 Speaker Replacement: passo 6, imagem 2 %32
    • Using the black spudger, push the white plastic connector out of the the tan plug.
  7. Lenovo ThinkPad X280 Speaker Replacement: passo 7, imagem 1 %32
    • Remove speakers and wiring from device.
Conclusão
Jordan Wooten
Membro desde: 09/05/21
588 Reputação
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 39
Duração total: 1,378
