Ir para o conteúdo principal
Lenovo ThinkPad X140e Keyboard Replacement
O que você precisa
  1. Lenovo ThinkPad X140e Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Set the laptop facing you with the screen open.
    Pergunte ao FixBot
    Comentar
  2. Lenovo ThinkPad X140e Keyboard Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad X140e Keyboard Replacement: passo 2, imagem 2 %32
    • Using a small plastic opening tool, pry off the keyboard starting at a point closest to you and working around the perimeter.
    Pergunte ao FixBot
    Comentar
  3. Lenovo ThinkPad X140e Keyboard Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad X140e Keyboard Replacement: passo 3, imagem 2 %32 Lenovo ThinkPad X140e Keyboard Replacement: passo 3, imagem 3 %32
    • Flip up the ZIF connector that is holding the small ribbon cable in place.
    • Proceed to pull out the small ribbon cable
    Pergunte ao FixBot
    Comentar
  4. Lenovo ThinkPad X140e Keyboard Replacement: passo 4, imagem 1 %32 Lenovo ThinkPad X140e Keyboard Replacement: passo 4, imagem 2 %32 Lenovo ThinkPad X140e Keyboard Replacement: passo 4, imagem 3 %32
    • Flip up the ZIF connector that is holding the larger ribbon cable in place.
    • Proceed to pull out the large ribbon cable.
    Pergunte ao FixBot
    Comentar
Conclusão
kevin hull
Membro desde: 10/05/16
219 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 20-5, Livingston Fall 2016 Membro de Cal Poly, Team 20-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G5
4 Membros
Autoria de 5 guias
4Comentários do guia
how can I buy a keyboard for my lenovo thinkpad x140e laptop?
Bryan - Responder Compartilhar
The keyboard for the X140e is the same as the one for the X130e and the X131e and the X121e.
It is FRU 04y0379
Buy the keyboard on eBay.
atexit8 - Responder Compartilhar
Just as a note, there are two screws that keep that keyboard held in place. You need to remove the back panel and take out those two screws, otherwise you’re going to have a tough time. Also, you really don’t need the pry tool, once those screws are out, the keyboard slides off. The rest of the process is spot on.
Jeffrey Chocklette - Responder Compartilhar
Don’t forget the screws, otherwise you will never get the keyboard off or worse damage it during removal
celticxxtwin - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 45
Ao todo: 2,281
