Ir para o conteúdo principal
Lenovo ThinkPad X100e Screen Replacement
O que você precisa
    1. Lenovo ThinkPad X100e Screen Replacement, Screen: passo 1, imagem 1 %32 Lenovo ThinkPad X100e Screen Replacement, Screen: passo 1, imagem 2 %32
      Ferramenta utilizada neste passo:
      Spudger
      $2.99
      • Use a Spudger tool to remove the screw covers on each side of the screen.
      • Be sure not to lose screw covers.
      Pergunte ao FixBot
      Comentar
    2. Lenovo ThinkPad X100e Screen Replacement: passo 2, imagem 1 %32
      • Using a magnetic screwdriver fit with a PH0 Bit, unscrew the two screws and carefully set the aside.
      Pergunte ao FixBot
      Comentar
    3. Lenovo ThinkPad X100e Screen Replacement: passo 3, imagem 1 %32
      • Pry open the bezel carefully with the spudger tool.
      • You will want to do this until the frame is completely off.
      Pergunte ao FixBot
      Comentar
    4. Lenovo ThinkPad X100e Screen Replacement: passo 4, imagem 1 %32
      • Remove all exposed screws and carefully set them aside. There should be 6 visible screws.
      • Be sure to set the screws aside on the magnetic mat.
      Pergunte ao FixBot
      Comentar
    5. Lenovo ThinkPad X100e Screen Replacement: passo 5, imagem 1 %32
      • Lift the screen up carefully, and remove the screws on both sides of the panel. There should be 4 screws.
      • The other two screws are located in the exact place on the other side.
      • Don't forget to place the screws on the magnetic mat, separate from other screws.
      Pergunte ao FixBot
      Comentar
    6. Lenovo ThinkPad X100e Screen Replacement: passo 6, imagem 1 %32 Lenovo ThinkPad X100e Screen Replacement: passo 6, imagem 2 %32
      • Remove the connector located at the very top of the screen beside the webcam.
      • To remove the connector, simply pull the connector out.
      Pergunte ao FixBot
      Comentar
    7. Lenovo ThinkPad X100e Screen Replacement: passo 7, imagem 1 %32
      • Fold the panel over until a strip of black tape is visible.
      • Peel the tape down until you get to the base.
      Pergunte ao FixBot
      Comentar
    8. Lenovo ThinkPad X100e Screen Replacement: passo 8, imagem 1 %32 Lenovo ThinkPad X100e Screen Replacement: passo 8, imagem 2 %32
      • Peel the piece of transparent tape back.
      • At this point there should be some exposed wires underneath the tape.
      Pergunte ao FixBot
      Comentar
    9. Lenovo ThinkPad X100e Screen Replacement: passo 9, imagem 1 %32
      • Remove the connector carefully with the spudger tool.
      Pergunte ao FixBot
      Comentar
    10. Lenovo ThinkPad X100e Screen Replacement: passo 10, imagem 1 %32
      • Remove the black tape fully.
      • Now your device is ready for a new panel.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Orly Guerra
Membro desde: 02/08/18
448 Reputação
Autoria de 2 guias
1Comentário do guia
What can be used as a replacement screen, as it's listed not for sale?
Keith Bowe - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 30
Ao todo: 1,345
