Ir para o conteúdo principal
Lenovo ThinkPad X1 Yoga Cooling Fan Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Yoga Cooling Fan Replacement, Back Cover: passo 1, imagem 1 %32 Lenovo ThinkPad X1 Yoga Cooling Fan Replacement, Back Cover: passo 1, imagem 2 %32 Lenovo ThinkPad X1 Yoga Cooling Fan Replacement, Back Cover: passo 1, imagem 3 %32
    • Be sure to power off and unplug your device before you begin your repair.
    • Flip the computer over so the bottom is facing up.
    • Remove nine 4mm Phillips #1 screws from the bottom of the computer.
    • Use an iFixit opening tool to pry the back cover off of the laptop.
  2. Lenovo ThinkPad X1 Yoga Cooling Fan Replacement, Cooling Fan: passo 2, imagem 1 %32
    • Remove four 4.5mm Phillips #1 screws from the corners of the heat sink.
  3. Lenovo ThinkPad X1 Yoga Cooling Fan Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad X1 Yoga Cooling Fan Replacement: passo 3, imagem 2 %32 Lenovo ThinkPad X1 Yoga Cooling Fan Replacement: passo 3, imagem 3 %32
    • Gently peel back the black plastic covering around the fan.
    • You may hear or feel the adhesive pulling away here.
    • Using an iFixit opening tool, flip up the small black cover of the fan plug.
  4. Lenovo ThinkPad X1 Yoga Cooling Fan Replacement: passo 4, imagem 1 %32 Lenovo ThinkPad X1 Yoga Cooling Fan Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers, pull the plastic strip out.
  5. Lenovo ThinkPad X1 Yoga Cooling Fan Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad X1 Yoga Cooling Fan Replacement: passo 5, imagem 2 %32
    • Remove the fan from the computer.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 25
Últimos 30 dias: 127
Duração total: 6,279
