Ir para o conteúdo principal
Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement, Back Cover: passo 1, imagem 1 %32
    • Ensure the laptop is powered off and the charging cable is disconnected before opening the back cover.
    • Flip over the laptop to access the back cover.
  2. Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement: passo 2, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the eight 8 mm screws.
    More pricesely, screws need to be unscrewed, but not removed, since they stay attached to the back cover. Trying to remove them may damage the small gaskets around the screw shaft.
    Edouard Rossignol - Responder
  3. Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement: passo 3, imagem 1 %32
    • Remove the back cover.
    • A popping sound may occur when the back cover is removed.
    Good solution, but where do I find the battery?
    Brian Arnold - Responder
  4. Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement, SSD: passo 4, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove one 6 mm screw.
  5. Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement: passo 5, imagem 2 %32
    • Slide the SSD out of the shiny covering.
    • Remove the SSD.
Conclusão
9 outras pessoas executaram este guia.
Equipe
Cal Poly, Team S22-G3, Regan Winter 2020 Membro de Cal Poly, Team S22-G3, Regan Winter 2020
CPSU-REGAN-W20S22G3
5 Membros
Autoria de 7 guias
1Comentário do guia
What kind of SSD is this compatible with? There are several different connector standards…
Shai Revzen - Responder
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 21
Últimos 30 dias: 96
Ao todo: 8,137
