Ir para o conteúdo principal
Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Base Panel: passo 1, imagem 1 %32 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Base Panel: passo 1, imagem 2 %32 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Base Panel: passo 1, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the five 5.0 mm screws from the base panel.
    • Wedge a spudger between the base panel and chassis, and pry around the entire perimeter until you hear a pop and the base panel releases.
    • Lift the base panel up and off of the chassis.
  2. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Battery: passo 2, imagem 1 %32 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Battery: passo 2, imagem 2 %32 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Battery: passo 2, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the five 4.5 mm screws securing the battery.
    • Lift the battery up and out.
  3. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Speaker: passo 3, imagem 1 %32 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Speaker: passo 3, imagem 2 %32 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Speaker: passo 3, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the four 1.8 mm screws.
  4. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: passo 4, imagem 1 %32 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: passo 4, imagem 2 %32 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: passo 4, imagem 3 %32
    • Use the spudger to lift the flap covering the speaker wire.
    • Starting at the top of the right speaker, follow the wire connected to the top of the left speaker. Use the tip of a spudger to free the wire from the plastic brackets it lies under.
    • Starting from near the bottom-left side of the right speaker, follow the lower wire, unseating the speaker cable as you go.
  5. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: passo 5, imagem 2 %32 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: passo 5, imagem 3 %32
    • Place your fingernails behind each of the plastic tabs on the speaker's plug and pull directly backwards until the plug releases from its port.
    • Lift the speakers up and out.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 17
Duração total: 352
