Ir para o conteúdo principal
Lenovo ThinkPad X1 Yoga (6th Gen) Battery Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Yoga (6th Gen) Battery Replacement, Base Panel: passo 1, imagem 1 %32 Lenovo ThinkPad X1 Yoga (6th Gen) Battery Replacement, Base Panel: passo 1, imagem 2 %32 Lenovo ThinkPad X1 Yoga (6th Gen) Battery Replacement, Base Panel: passo 1, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the five 5.0 mm screws from the base panel.
    • Wedge a spudger between the base panel and chassis, and pry around the entire perimeter until you hear a pop and the base panel releases.
    • Lift the base panel up and off of the chassis.
  2. Lenovo ThinkPad X1 Yoga (6th Gen) Battery Replacement, Battery: passo 2, imagem 1 %32 Lenovo ThinkPad X1 Yoga (6th Gen) Battery Replacement, Battery: passo 2, imagem 2 %32 Lenovo ThinkPad X1 Yoga (6th Gen) Battery Replacement, Battery: passo 2, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the five 4.5 mm screws securing the battery.
    • Lift the battery up and out.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 20
Últimos 30 dias: 109
Duração total: 1,844
