Ir para o conteúdo principal
Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement, Wireless Adapter: passo 1, imagem 1 %32 Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement, Wireless Adapter: passo 1, imagem 2 %32
    • Orient the laptop so that it is bottom up, and the track pad is closet to you.
    • Unscrew the seven cover screws with a Phillips #00 head screwdriver. These screws will loosen but will stay attached to the cover.
    • Slide the blue opening pick along the side of the laptop and pry off the one clip on each side.
  2. Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: passo 2, imagem 2 %32
    • Using a Phillips #00 head screwdriver, remove the 3mm screw holding the wireless adapter to the motherboard.
  3. Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: passo 3, imagem 2 %32 Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: passo 3, imagem 3 %32
    • Slide the chip to the right carefully until the wireless adapter pops out.
    • Disconnect the grey and black wires by lifting them off straight up until they pop off the wireless adapter.
    • The chip should be completely removed from the computer and you are done.
Conclusão
Beckham Richmond
Membro desde: 02/10/20
467 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S7-G3, Regan Winter 2020 Membro de Cal Poly, Team S7-G3, Regan Winter 2020
CPSU-REGAN-W20S7G3
Membros da 4
Autoria de 8 guias
Um comentário
Hi, does the Lenovo X1 Extreme Gen 1 support Wifi 6 or 6e? If so what which card?
I tried the:
"AX210NGW WiFi Card, Wi-Fi 6E 11AX Wireless Module Expand to 6GHz MU-MIMO Tri-Band Bluetooth 5.3 Internal Network Adapter for Laptop, Support Windows 10/11 64bit, M.2/NGFF"
Wifi worked but Bluetooth wasn't recognized.
Captainturk - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 48
Duração total: 1,990
