Ir para o conteúdo principal
Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement, Back Cover: passo 1, imagem 1 %32
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement, Battery: passo 3, imagem 1 %32 Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement, Battery: passo 3, imagem 2 %32
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement: passo 4, imagem 1 %32
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement: passo 5, imagem 1 %32
    • Remove the battery by pulling it directly towards you.
  6. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement, USB Audio Port Board: passo 6, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the 2.9 mm screw that is holding down the USB audio port board.
  7. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement: passo 7, imagem 1 %32 Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement: passo 7, imagem 2 %32
    • Undo the clasp under the USB audio port board.
  8. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement: passo 8, imagem 1 %32
    • Remove the USB audio port board from the laptop.
Conclusão
Eevee Murdock
Membro desde: 01/23/20
1.074 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team S18-G4, White Winter 2020 Membro de Cal Poly, Team S18-G4, White Winter 2020
CPSU-WHITE-W20S18G4
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 16
Duração total: 949
