Ir para o conteúdo principal
Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement, Back Cover: passo 1, imagem 1 %32
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement, Battery: passo 3, imagem 1 %32 Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement, Battery: passo 3, imagem 2 %32
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: passo 4, imagem 1 %32
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: passo 5, imagem 1 %32
    • Remove the battery by pulling it directly towards you.
  6. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement, Touchpad: passo 6, imagem 1 %32
    • Remove the black ribbon cable connected to the touchpad.
  7. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: passo 7, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the four 1.9 mm screws holding in the touchpad.
  8. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: passo 8, imagem 1 %32
    • Remove the touchpad by opening the computer and letting it drop onto your hand.
Conclusão
Uma outra pessoa concluiu este guia.
Eevee Murdock
Membro desde: 01/23/20
1.086 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team S18-G4, White Winter 2020 Membro de Cal Poly, Team S18-G4, White Winter 2020
CPSU-WHITE-W20S18G4
Membros da 4
Autoria de 9 guias
2 comentários
Even the weirder of their models is still amazingly engineered, this was so easy to do and finding parts - not only of the same model but compatible newer parts - was an absolute breeze! Was able to upgrade my laptop during my work lunchtime, and still have time to actually eat lunch!
Casey - Responder
Just to confirm - Thinkpad X1 Carbon Generation 3 touchpads are compatible with this model, and make for an amazing upgrade.
Casey - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 27
Duração total: 1,749
