Ir para o conteúdo principal
Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement, Back Cover: passo 1, imagem 1 %32
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement, Battery: passo 3, imagem 1 %32 Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement, Battery: passo 3, imagem 2 %32
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: passo 4, imagem 1 %32
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: passo 5, imagem 1 %32
    • Remove the battery by pulling it directly towards you.
  6. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement, Speakers: passo 6, imagem 1 %32 Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement, Speakers: passo 6, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the four 4.6mm screws holding the speakers.
    • Each speaker has 2 screws.
  7. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: passo 7, imagem 1 %32 Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: passo 7, imagem 2 %32
    • Disconnect the wire running from the right speaker to the motherboard.
  8. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: passo 8, imagem 1 %32 Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: passo 8, imagem 2 %32
    • Remove the tape that is holding down the wire that connects the two speakers.
  9. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: passo 9, imagem 1 %32
    • Remove the speakers by lifting them directly upward.
Conclusão
Eevee Murdock
Membro desde: 01/23/20
1.002 Reputação
6 Guias de autoria
Equipe
Cal Poly, Team S18-G4, White Winter 2020 Membro de Cal Poly, Team S18-G4, White Winter 2020
CPSU-WHITE-W20S18G4
4 Membros
7 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 21
Duração total: 772
