Ir para o conteúdo principal
Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Back Cover: passo 1, imagem 1 %32
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Battery: passo 3, imagem 1 %32 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Battery: passo 3, imagem 2 %32
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: passo 4, imagem 1 %32
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: passo 5, imagem 1 %32
    • Remove the battery by pulling it directly towards you.
  6. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Fan: passo 6, imagem 1 %32
    • Use a Phillips #1 screwdriver to undo the four 5 mm screws attached to the heat sink.
  7. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: passo 7, imagem 1 %32
    • Undo the black clasp that holds the ribbon cable, attached to the fan, in place and disconnect the ribbon cable.
  8. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: passo 8, imagem 1 %32
    • Remove the fan by lifting it directly up.
  9. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Motherboard: passo 9, imagem 1 %32 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Motherboard: passo 9, imagem 2 %32
    • Disconnect all 10 of the ribbon cables attached to the motherboard.
  10. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: passo 10, imagem 1 %32 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: passo 10, imagem 2 %32
    • Disconnect the wire connecting the motherboard to the speaker.
  11. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: passo 11, imagem 1 %32
    • Use a Phillips #1 screwdriver to unscrew the 4mm screw holding the metal covering over the power jack prongs.
  12. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: passo 12, imagem 1 %32
    • Use a Phillips #1 screwdriver to unscrew the 4mm screw holding down the Micro-SD card tray.
  13. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: passo 13, imagem 1 %32 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: passo 13, imagem 2 %32
    • Un-tape the orange and blue wires from the motherboard.
  14. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: passo 14, imagem 1 %32
    • Remove the black and grey wires from the cable comb on the motherboard.
  15. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: passo 15, imagem 1 %32 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: passo 15, imagem 2 %32
    • Use a Phillips #1 screwdriver to unscrew the 3.7mm screw holding down the wifi card.
    • Remove the wifi card.
  16. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: passo 16, imagem 1 %32 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: passo 16, imagem 2 %32
    • Carefully remove the motherboard by lifting it and pulling towards the left.
Conclusão
3 outras pessoas executaram este guia.
Eevee Murdock
Membro desde: 01/23/20
1.002 Reputação
6 Guias de autoria
Equipe
Cal Poly, Team S18-G4, White Winter 2020 Membro de Cal Poly, Team S18-G4, White Winter 2020
CPSU-WHITE-W20S18G4
4 Membros
7 Guias de autoria
2 comentários
All going as described, until the final step trying to pull the motherboard out, and there is something still holding it in place. With a bit of a wiggle and pull, there is something about near the screw hole that was holding the wifi card down preventing the card from lifting there. Any clues?
Tim Ellison - Responder
Answering my own question: Removing the motherboard requires that you first pop the SIM card / MicroSD card holder out of the socket, otherwise it won’t lift out. Submitted an update to the guide to save others falling into the same trap.
Tim Ellison -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 30
Últimos 30 dias: 115
Duração total: 2,801
