Introdução
If your programs began to slow down your laptop, or programs continue to hang under load, then this guide should help you replace the RAM/Memory stick within your laptop. This guide is also helpful in the case that you need to upgrade your laptop's RAM sticks.
O que você precisa
Flip your laptop to the bottom so that the backplate is shown.
Unscrew the captive screws on the backplate with a Phillips #0 screwdriver.
