Ir para o conteúdo principal
Lenovo ThinkPad W540 Display Replacement
O que você precisa
  1. Lenovo ThinkPad W540 Display Replacement, Display: passo 1, imagem 1 %32 Lenovo ThinkPad W540 Display Replacement, Display: passo 1, imagem 2 %32
    • Open your laptop so that the screen is at around a 180 degree angle.
    • Using a plastic opening tool, pry open the outer frame of the display.
    • Generally, it is best practice to start from the corner first, and then guide the opening tool around the the frame.
    Pergunte ao FixBot
    Comentar
  2. Lenovo ThinkPad W540 Display Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad W540 Display Replacement: passo 2, imagem 2 %32
    • Use a Phillips #00 screwdriver to unscrew the four 3 mm screws holding the display, one for each corner.
    • Once unscrewed, flip the display over the other side of the laptop (keyboard end).
    Pergunte ao FixBot
    Comentar
  3. Lenovo ThinkPad W540 Display Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad W540 Display Replacement: passo 3, imagem 2 %32
    • Use a plastic spudger, safety lift the adhesive tape from the connector.
    • Do not disregard the tape from the connector entirely as you will be reusing it later.
    • This adhesive tape will be strong, remove the tape carefully to prevent damage to the display connector.
    Pergunte ao FixBot
    Comentar
  4. Lenovo ThinkPad W540 Display Replacement: passo 4, imagem 1 %32
    • Safely disconnect the display from the connector.
    • Although you can use your hands to disconnect the connector, it is recommended that you use a spudger instead.
    Pergunte ao FixBot
    Comentar
Conclusão
Kevin Dang
Membro desde: 10/30/23
360 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 3-2, Konn Fall 2023 Membro de UMass Dartmouth, Team 3-2, Konn Fall 2023
UMASSD-KONN-F23S3G2
3 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 16
Últimos 30 dias: 62
Ao todo: 885
